Install error
bearqst
phpBB.com User: bearqst
Install error
Post by bearqst »
Your Portal Version: 1.0.2
Boardlink: http://www.dancealaska.org
Installed phpbb3, migrated sql dB, used Colorisit to change the colors in ProSilver.
Searched php sites for info. Looked at the schema files to consider doing manual sql import (still think this is the answer)
After running through all the mod files, uploading them, I tried to go to
./install_portal/install.php
What I get is
PInUp Error
You must be logged in as an admin.
Go to login
This even logged in as an Admin as the error says. This is my 2nd board install, first one went fine.
I think this is a directory permissions issue ??
I can run the sql from phpmyadmin, but I'm not 100% sure which one to run. I'm running mysql 5.0
The mysql schema's that show in schema directory are 40, 41 and "update_
So do I run the content from "update_schema" ?
TIA
bearqst
Re: Install error
Post by bearqst »
Additional Info.
I found the post from October knowledge/kb_show.php?id=14
Which said find/remove
if( $user->data['is_registered'] && $auth->acl_get('a_') )
I did, and now when I try to go to ././install.ph_ I get a blank page. No error, no nothing.
The 2nd part of the code to remove
    } else {
                     include($phpbb_root_path . 'install_portal/style/layout_header.'.$phpEx);
                     echo '' . $user->lang['INSTALLER_ERROR'] . '';
                     echo '' . $user->lang['INSTALLER_NEEDS_ADMIN'] . '';
                     include($phpbb_root_path . 'install_portal/style/layout_footer.'.$phpEx);
Did not exist.
Re: Install error
Try this already modified installer: download/file.php?id=130
Delete the install directory right afterwards!
bearqst
Re: Install error
Post by bearqst »
Thanks Kevin,
That fixed it. Maybe a bad installer in the package I DL'd ?
Curious why it worked on my first board but not on the 2nd.
I'll do a little digging and see if I can figure out why. I'll post back what I find, if anything.
Thanks again, great mod for phpbb3
Re: Install error
No, not a bad installer in the package. Just a problems in special circumstances, that should be fixed with the next release (we thought that already before).
bearqst wrote:Curious why it worked on my first board but not on the 2nd.
That would be great if you can tell us which difference between the boards caused this problem. The more we know... ;)
