Your Portal Version: 1.0.2
Boardlink: http://www.venom-forum.co.uk
PHP Version: 4.5
I have installed board 3 portal without a hitch and everything seems to be working however my phpbb3 install is on the root of my webserver so when i goto my web address www.venom-forum.co.uk it goes straight into the forum rather than the prtal which is at portal.php, how can i make this happen?
Cheers in advance for the help
How to make portal.php default page
Re: How to make portal.php default page
You might try to do the changes to the .htaccess file as mentioned in the install.xml.
He cant use the .htaccess, as he is hosted on IIS.
He can ask his hoster, or - if it is his own server - set the defaullt page in the IIS management. But .htaccess only works with Apache.Internet Information Services (IIS)
Hi i have editted the .htaccess file and changed it to what the install says and have even tried it with just portal.php in there but it still wont work.
Is this because im on a windows server and i need to get my webhosting company to edit the file?
Yes, this is what i said.Ultim8 wrote:Is this because im on a windows server
Yes / No.Ultim8 wrote:and i need to get my webhosting company to edit the file?
You need to ask your webhosting company to set the portal.php as start page. But this is not done with a .htaccess, it have to be configured in the IIS server.
Maybe your webhoster offers something similar to confixx (a configuration web interface), where you can set start pages for your domains.
One of two things.Ultim8 wrote:Hi i have editted the .htaccess file and changed it to what the install says and have even tried it with just portal.php in there but it still wont work.
Ask your web hosting company to change your default web site document to portal.php, as Kevin said.
Or try to add a redirect in your root.
header( 'Location: http://www.yourdoman.com/portal.php' ) ;
Warning: If your default document is index.php
Then you back to contacting your web hosting company.
- phpBB.com User: DragonMaster1
You could also change your domain to a URL redirect and have it land on the portal page
- phpBB.de User: danleedham
- phpBB.com User: danleedham
one way I got it working... (on a server that i didn't set up - I'd use Apache being an Apple Server Guru)
create a file index.html on your root and paste this:
It doesn't work for everything / everyone... but does for some...
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head><title></title><meta http-equiv="refresh" content="0;url= portal.php" /></head><body></body></html>
hi
I've got the same problem and I've got access to a plesk control panel (v8.6.0) but I don't have the slightest clue where to edit the default page for my forum's root
I've searched for about an hour now and my hoster guy doesn't seem to have an idea, too -.-
