Boardlink: http://www.newoutriders.com/nortest/portal.php
n/a
Tried a bazlion test. nothing worked.
![Traurig :(](./images/smilies/icon_e_sad.gif)
I am trying to change the background color of my "custom block". I am using a style that was made for my boards. It is currently black.
I looked through the .css of the custom style & the .css of the portal and I cannot figure it out. I even tried just adding a background color in the html I posted in the custom block, but that didn't work either.
I tried everything with the custom block - custom_center.html & custom_small.html and nothing works.
I just want to change the background on that one block. The custom .css has "panel" in it, but the color is 303030, not black like it is showing.
As you can see the background is currently black. Can anyone give me a head's up on how I can change the background color for that block?
