Your Portal Version: 1.0.1
edit css'
Hi there,
In the acp I changed my logo and it works for the Fora however on our portal it only shows a grey box where the logo should be what do i need to edit?
Logo not showing
Re: Logo not showing
Okay I figured it out the style I am using doesn't use wrapheader for the logo is there a way to make the portal not use wrapheader aswell?
Here's where the style places the logo
#logodesc {
background-image: url(images/logod.png);
height: 98px;
width: auto;
padding-right: 25px;
padding-left: 25px;
background-repeat: repeat-x;
#logodesc {
height: 98px;
width: auto;
padding-left: 25px;
Have you tried going to ACP - Styles - Image Sets - Edit - In the drop down menu make sure Main Logo is shown - then browse through the images to find your one. If its no there then upload to the correct folder..
