Your Portal Version: 1.0.6
Boardlink: http://www.pacificgamerz.com
PHP Version: 3.08
I only installed Board 3 portal today, I used the standard Prosilver theme, and just wanted to get rid of the stock look by installing a optional theme to the style block.
i haven't tried anything other than checking my install, and edited files.
Theme appears to narrow for portal.
Battlefield Bad Company 2 Portal.
Re: Battlefield Bad Company 2 Portal.
Since I can not interpret your post correctly, I wonder if you have already read this?
viewtopic.php?f=47&t=4521
Yes i tried that i had already posted.
If you select the Battlefield style from the dropdown, you can see what i mean.
#1The "latest News" area seems to small and sits over the icons.
#2The "poll" area displays no bars.
You have taken the prosilver files.scoteye wrote: Boardlink: http://www.pacificgamerz.com
You have to take subsilver2 files from the portal.
This is also in the manual!
to: styles/Bad_Company_2_v2/template/portal/*.*
to: styles/Bad_Company_2_v2/theme/images/portal/*.*
