Parse error: syntax error.
Estrellita
phpBB.com User: LitaLa
Post by Estrellita »
Your Portal Version: 1.0.6
Boardlink: http://snach.net/phpBB3/index.php
Installed phpBB3 (no problems) & then installed Board3 (no problems) I can make all the changes via ACP on the .MODs Tab.
Upon finishing install I cannot access the Portal.
I have tried numerous things to fix this error & hours of reading through forums & posts.
Here is the error I recieve as I try to access My Portal & now also my Board Index is down :cry:
Parse error: syntax error, unexpected $end in /clientdata/zeus-dynamic-1/s/n/snach.net/www/phpBB3/cache/tpl_prosilver_overall_header.html.php on line 190
Here is my Code for my overall_header.html:
<head>
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7; IE=EmulateIE9" />
{META}
<!-- IF S_ENABLE_FEEDS -->
	phpBB style name: prosilver
	Based on style:   prosilver (this is the default phpBB3 style)
	Modified by:
// <![CDATA[
	var on_page = '{ON_PAGE}';
	var per_page = '{PER_PAGE}';
	<!-- IF S_USER_PM_POPUP -->
		if ({S_NEW_PM})
			var url = '{UA_POPUP_PM}';
	* Find a member
	function find_username(url)
		return false;
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
</head>
<div id="wrap">
	<div id="page-header">
		<div class="headerbar">
			<div id="site-description">
				<h1>{SITENAME}</h1>
				<p>{SITE_DESCRIPTION}</p>
				<p class="skiplink"><a href="#start_here">{L_SKIP}</a></p>
			<div id="search-box">
				<fieldset>
				</fieldset>
				</form>
				<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a>&#187;<!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a><strong>&#8249;</strong><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li>
				<li class="icon-ucp">
					<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{L_PROFILE}</a>
						<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF -->
					<!-- IF S_DISPLAY_SEARCH --> &bull;
				</li>
				<!-- IF not S_IS_BOT -->
					<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><li class="icon-register"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
	<div id="page-body">
		<div id="information" class="rules">
I have refreshed my templates/themes & imagesets & cleared my cache many times.
I'm very new to PHP (All of 2 days lol) so a little help in the right direction would be greatly appreciated :D[/i]
Re: Parse error: syntax error.
Estrellita wrote: Boardlink: http://snach.net/phpBB3/index.php
You have forgotten the code in the file to install.
Check the overall_header.html with install.xml for the portal.
Estrellita
I'm not sure if I'm editing the code right when doing this part of the install.xml:
:Select all
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong>
Select all
:Select all
How should this be entered? Just insert after
& not delete
or do i replace that with
Sorry I'm really really NOOB with PHP lol... Throwing myself into the deep end just to get a website running for my Guild :?
It must be like this:
1.)
2.)
Estrellita
I am now encountering this error:
Parse error: syntax error, unexpected $end in /clientdata/zeus-dynamic-1/s/n/snach.net/www/phpBB3/cache/tpl_prosilver_overall_header.html.php on line 191
Here is my code:
<?php if (!defined('IN_PHPBB')) exit; ?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="<?php echo (isset($this->_rootref['S_CONTENT_DIRECTION'])) ? $this->_rootref['S_CONTENT_DIRECTION'] : ''; ?>" lang="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>" xml:lang="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>">
<head>
<meta http-equiv="content-type" content="text/html; charset=<?php echo (isset($this->_rootref['S_CONTENT_ENCODING'])) ? $this->_rootref['S_CONTENT_ENCODING'] : ''; ?>" />
<meta http-equiv="content-language" content="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>" />
<?php echo (isset($this->_rootref['META'])) ? $this->_rootref['META'] : ''; ?>
<title><?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?> &bull; <?php if ($this->_rootref['S_IN_MCP']) {  echo ((isset($this->_rootref['L_MCP'])) ? $this->_rootref['L_MCP'] : ((isset($user->lang['MCP'])) ? $user->lang['MCP'] : '{ MCP }')); ?> &bull; <?php } else if ($this->_rootref['S_IN_UCP']) {  echo ((isset($this->_rootref['L_UCP'])) ? $this->_rootref['L_UCP'] : ((isset($user->lang['UCP'])) ? $user->lang['UCP'] : '{ UCP }')); ?> &bull; <?php } echo (isset($this->_rootref['PAGE_TITLE'])) ? $this->_rootref['PAGE_TITLE'] : ''; ?></title>
<?php if ($this->_rootref['S_ENABLE_FEEDS']) {  if ($this->_rootref['S_ENABLE_FEEDS_OVERALL']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_NEWS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_NEWS'])) ? $this->_rootref['L_FEED_NEWS'] : ((isset($user->lang['FEED_NEWS'])) ? $user->lang['FEED_NEWS'] : '{ FEED_NEWS }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=news" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_FORUMS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_ALL_FORUMS'])) ? $this->_rootref['L_ALL_FORUMS'] : ((isset($user->lang['ALL_FORUMS'])) ? $user->lang['ALL_FORUMS'] : '{ ALL_FORUMS }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=forums" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPICS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_TOPICS_NEW'])) ? $this->_rootref['L_FEED_TOPICS_NEW'] : ((isset($user->lang['FEED_TOPICS_NEW'])) ? $user->lang['FEED_TOPICS_NEW'] : '{ FEED_TOPICS_NEW }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=topics" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPICS_ACTIVE']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_TOPICS_ACTIVE'])) ? $this->_rootref['L_FEED_TOPICS_ACTIVE'] : ((isset($user->lang['FEED_TOPICS_ACTIVE'])) ? $user->lang['FEED_TOPICS_ACTIVE'] : '{ FEED_TOPICS_ACTIVE }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=topics_active" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_FORUM'] && $this->_rootref['S_FORUM_ID']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FORUM'])) ? $this->_rootref['L_FORUM'] : ((isset($user->lang['FORUM'])) ? $user->lang['FORUM'] : '{ FORUM }')); ?> - <?php echo (isset($this->_rootref['FORUM_NAME'])) ? $this->_rootref['FORUM_NAME'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?f=<?php echo (isset($this->_rootref['S_FORUM_ID'])) ? $this->_rootref['S_FORUM_ID'] : ''; ?>" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPIC'] && $this->_rootref['S_TOPIC_ID']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_TOPIC'])) ? $this->_rootref['L_TOPIC'] : ((isset($user->lang['TOPIC'])) ? $user->lang['TOPIC'] : '{ TOPIC }')); ?> - <?php echo (isset($this->_rootref['TOPIC_TITLE'])) ? $this->_rootref['TOPIC_TITLE'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?f=<?php echo (isset($this->_rootref['S_FORUM_ID'])) ? $this->_rootref['S_FORUM_ID'] : ''; ?>&t=<?php echo (isset($this->_rootref['S_TOPIC_ID'])) ? $this->_rootref['S_TOPIC_ID'] : ''; ?>" /><?php } } ?>
	Modified by:
// <![CDATA[
	var jump_page = '<?php echo ((isset($this->_rootref['LA_JUMP_PAGE'])) ? $this->_rootref['LA_JUMP_PAGE'] : ((isset($this->_rootref['L_JUMP_PAGE'])) ? addslashes($this->_rootref['L_JUMP_PAGE']) : ((isset($user->lang['JUMP_PAGE'])) ? addslashes($user->lang['JUMP_PAGE']) : '{ JUMP_PAGE }'))); ?>:';
	var on_page = '<?php echo (isset($this->_rootref['ON_PAGE'])) ? $this->_rootref['ON_PAGE'] : ''; ?>';
	var per_page = '<?php echo (isset($this->_rootref['PER_PAGE'])) ? $this->_rootref['PER_PAGE'] : ''; ?>';
	var base_url = '<?php echo (isset($this->_rootref['A_BASE_URL'])) ? $this->_rootref['A_BASE_URL'] : ''; ?>';
	var style_cookie_settings = '<?php echo (isset($this->_rootref['A_COOKIE_SETTINGS'])) ? $this->_rootref['A_COOKIE_SETTINGS'] : ''; ?>';
	<?php if ($this->_rootref['S_USER_PM_POPUP']) {  ?>
		if (<?php echo (isset($this->_rootref['S_NEW_PM'])) ? $this->_rootref['S_NEW_PM'] : ''; ?>)
			var url = '<?php echo (isset($this->_rootref['UA_POPUP_PM'])) ? $this->_rootref['UA_POPUP_PM'] : ''; ?>';
	<?php } ?>
	* Find a member
		return false;
</script>
<script type="text/javascript" src="<?php echo (isset($this->_rootref['T_TEMPLATE_PATH'])) ? $this->_rootref['T_TEMPLATE_PATH'] : ''; ?>/styleswitcher.js"></script>
<script type="text/javascript" src="<?php echo (isset($this->_rootref['T_TEMPLATE_PATH'])) ? $this->_rootref['T_TEMPLATE_PATH'] : ''; ?>/forum_fn.js"></script>
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/print.css" rel="stylesheet" type="text/css" media="print" title="printonly" />
<link href="<?php echo (isset($this->_rootref['T_STYLESHEET_LINK'])) ? $this->_rootref['T_STYLESHEET_LINK'] : ''; ?>" rel="stylesheet" type="text/css" media="screen, projection" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/normal.css" rel="stylesheet" type="text/css" title="A" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/medium.css" rel="alternate stylesheet" type="text/css" title="A+" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/large.css" rel="alternate stylesheet" type="text/css" title="A++" />
<?php if ($this->_rootref['S_CONTENT_DIRECTION'] == ('rtl')) {  ?>
	<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/bidi.css" rel="stylesheet" type="text/css" media="screen, projection" />
<?php } ?>
</head>
<body id="phpbb" class="section-<?php echo (isset($this->_rootref['SCRIPT_NAME'])) ? $this->_rootref['SCRIPT_NAME'] : ''; ?> <?php echo (isset($this->_rootref['S_CONTENT_DIRECTION'])) ? $this->_rootref['S_CONTENT_DIRECTION'] : ''; ?>">
<div id="wrap">
				<a href="<?php echo (isset($this->_rootref['U_INDEX'])) ? $this->_rootref['U_INDEX'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?>" id="logo"><?php echo (isset($this->_rootref['SITE_LOGO_IMG'])) ? $this->_rootref['SITE_LOGO_IMG'] : ''; ?></a>
				<h1><?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?></h1>
				<p><?php echo (isset($this->_rootref['SITE_DESCRIPTION'])) ? $this->_rootref['SITE_DESCRIPTION'] : ''; ?></p>
				<p class="skiplink"><a href="#start_here"><?php echo ((isset($this->_rootref['L_SKIP'])) ? $this->_rootref['L_SKIP'] : ((isset($user->lang['SKIP'])) ? $user->lang['SKIP'] : '{ SKIP }')); ?></a></p>
		<?php if ($this->_rootref['S_DISPLAY_SEARCH'] && ! $this->_rootref['S_IN_SEARCH']) {  ?>
				<form action="<?php echo (isset($this->_rootref['U_SEARCH'])) ? $this->_rootref['U_SEARCH'] : ''; ?>" method="post" id="search">
				<fieldset>
					<input name="keywords" id="keywords" type="text" maxlength="128" title="<?php echo ((isset($this->_rootref['L_SEARCH_KEYWORDS'])) ? $this->_rootref['L_SEARCH_KEYWORDS'] : ((isset($user->lang['SEARCH_KEYWORDS'])) ? $user->lang['SEARCH_KEYWORDS'] : '{ SEARCH_KEYWORDS }')); ?>" class="inputbox search" value="<?php if ($this->_rootref['SEARCH_WORDS']) {  echo (isset($this->_rootref['SEARCH_WORDS'])) ? $this->_rootref['SEARCH_WORDS'] : ''; } else { echo ((isset($this->_rootref['L_SEARCH_MINI'])) ? $this->_rootref['L_SEARCH_MINI'] : ((isset($user->lang['SEARCH_MINI'])) ? $user->lang['SEARCH_MINI'] : '{ SEARCH_MINI }')); } ?>" onclick="if(this.value=='<?php echo ((isset($this->_rootref['LA_SEARCH_MINI'])) ? $this->_rootref['LA_SEARCH_MINI'] : ((isset($this->_rootref['L_SEARCH_MINI'])) ? addslashes($this->_rootref['L_SEARCH_MINI']) : ((isset($user->lang['SEARCH_MINI'])) ? addslashes($user->lang['SEARCH_MINI']) : '{ SEARCH_MINI }'))); ?>')this.value='';" onblur="if(this.value=='')this.value='<?php echo ((isset($this->_rootref['LA_SEARCH_MINI'])) ? $this->_rootref['LA_SEARCH_MINI'] : ((isset($this->_rootref['L_SEARCH_MINI'])) ? addslashes($this->_rootref['L_SEARCH_MINI']) : ((isset($user->lang['SEARCH_MINI'])) ? addslashes($user->lang['SEARCH_MINI']) : '{ SEARCH_MINI }'))); ?>';" />
					<input class="button2" value="<?php echo ((isset($this->_rootref['L_SEARCH'])) ? $this->_rootref['L_SEARCH'] : ((isset($user->lang['SEARCH'])) ? $user->lang['SEARCH'] : '{ SEARCH }')); ?>" type="submit" /><br />
					<a href="<?php echo (isset($this->_rootref['U_SEARCH'])) ? $this->_rootref['U_SEARCH'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_SEARCH_ADV_EXPLAIN'])) ? $this->_rootref['L_SEARCH_ADV_EXPLAIN'] : ((isset($user->lang['SEARCH_ADV_EXPLAIN'])) ? $user->lang['SEARCH_ADV_EXPLAIN'] : '{ SEARCH_ADV_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_SEARCH_ADV'])) ? $this->_rootref['L_SEARCH_ADV'] : ((isset($user->lang['SEARCH_ADV'])) ? $user->lang['SEARCH_ADV'] : '{ SEARCH_ADV }')); ?></a> <?php echo (isset($this->_rootref['S_SEARCH_HIDDEN_FIELDS'])) ? $this->_rootref['S_SEARCH_HIDDEN_FIELDS'] : ''; ?>
				</fieldset>
				</form>
		<?php } ?>
	    <?php if (! $this->_tpldata['DEFINE']['.']['S_IN_PORTAL'] || $this->_rootref['S_DISPLAY_PHPBB_MENU']) {  ?>
				<li class="icon-home"><a href="<?php echo (isset($this->_rootref['U_INDEX'])) ? $this->_rootref['U_INDEX'] : ''; ?>" accesskey="h"><?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?></a> <?php $_navlinks_count = (isset($this->_tpldata['navlinks'])) ? sizeof($this->_tpldata['navlinks']) : 0;if ($_navlinks_count) {for ($_navlinks_i = 0; $_navlinks_i < $_navlinks_count; ++$_navlinks_i){$_navlinks_val = &$this->_tpldata['navlinks'][$_navlinks_i]; ?> <strong>&#8249;</strong><?php if ($this->_rootref['U_PORTAL']) {  ?><a href="<?php echo (isset($this->_rootref['U_PORTAL'])) ? $this->_rootref['U_PORTAL'] : ''; ?>"><?php echo ((isset($this->_rootref['L_PORTAL'])) ? $this->_rootref['L_PORTAL'] : ((isset($user->lang['PORTAL'])) ? $user->lang['PORTAL'] : '{ PORTAL }')); ?></a> &#187; <?php } ?>
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="<?php echo ((isset($this->_rootref['L_CHANGE_FONT_SIZE'])) ? $this->_rootref['L_CHANGE_FONT_SIZE'] : ((isset($user->lang['CHANGE_FONT_SIZE'])) ? $user->lang['CHANGE_FONT_SIZE'] : '{ CHANGE_FONT_SIZE }')); ?>"><?php echo ((isset($this->_rootref['L_CHANGE_FONT_SIZE'])) ? $this->_rootref['L_CHANGE_FONT_SIZE'] : ((isset($user->lang['CHANGE_FONT_SIZE'])) ? $user->lang['CHANGE_FONT_SIZE'] : '{ CHANGE_FONT_SIZE }')); ?></a></li>
				<?php if ($this->_rootref['U_EMAIL_TOPIC']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_EMAIL_TOPIC'])) ? $this->_rootref['U_EMAIL_TOPIC'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_EMAIL_TOPIC'])) ? $this->_rootref['L_EMAIL_TOPIC'] : ((isset($user->lang['EMAIL_TOPIC'])) ? $user->lang['EMAIL_TOPIC'] : '{ EMAIL_TOPIC }')); ?>" class="sendemail"><?php echo ((isset($this->_rootref['L_EMAIL_TOPIC'])) ? $this->_rootref['L_EMAIL_TOPIC'] : ((isset($user->lang['EMAIL_TOPIC'])) ? $user->lang['EMAIL_TOPIC'] : '{ EMAIL_TOPIC }')); ?></a></li><?php } if ($this->_rootref['U_EMAIL_PM']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_EMAIL_PM'])) ? $this->_rootref['U_EMAIL_PM'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_EMAIL_PM'])) ? $this->_rootref['L_EMAIL_PM'] : ((isset($user->lang['EMAIL_PM'])) ? $user->lang['EMAIL_PM'] : '{ EMAIL_PM }')); ?>" class="sendemail"><?php echo ((isset($this->_rootref['L_EMAIL_PM'])) ? $this->_rootref['L_EMAIL_PM'] : ((isset($user->lang['EMAIL_PM'])) ? $user->lang['EMAIL_PM'] : '{ EMAIL_PM }')); ?></a></li><?php } if ($this->_rootref['U_PRINT_TOPIC']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_PRINT_TOPIC'])) ? $this->_rootref['U_PRINT_TOPIC'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PRINT_TOPIC'])) ? $this->_rootref['L_PRINT_TOPIC'] : ((isset($user->lang['PRINT_TOPIC'])) ? $user->lang['PRINT_TOPIC'] : '{ PRINT_TOPIC }')); ?>" accesskey="p" class="print"><?php echo ((isset($this->_rootref['L_PRINT_TOPIC'])) ? $this->_rootref['L_PRINT_TOPIC'] : ((isset($user->lang['PRINT_TOPIC'])) ? $user->lang['PRINT_TOPIC'] : '{ PRINT_TOPIC }')); ?></a></li><?php } if ($this->_rootref['U_PRINT_PM']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_PRINT_PM'])) ? $this->_rootref['U_PRINT_PM'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PRINT_PM'])) ? $this->_rootref['L_PRINT_PM'] : ((isset($user->lang['PRINT_PM'])) ? $user->lang['PRINT_PM'] : '{ PRINT_PM }')); ?>" accesskey="p" class="print"><?php echo ((isset($this->_rootref['L_PRINT_PM'])) ? $this->_rootref['L_PRINT_PM'] : ((isset($user->lang['PRINT_PM'])) ? $user->lang['PRINT_PM'] : '{ PRINT_PM }')); ?></a></li><?php } ?>
			<?php if (! $this->_rootref['S_IS_BOT'] && $this->_rootref['S_USER_LOGGED_IN']) {  ?>
					<a href="<?php echo (isset($this->_rootref['U_PROFILE'])) ? $this->_rootref['U_PROFILE'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PROFILE'])) ? $this->_rootref['L_PROFILE'] : ((isset($user->lang['PROFILE'])) ? $user->lang['PROFILE'] : '{ PROFILE }')); ?>" accesskey="e"><?php echo ((isset($this->_rootref['L_PROFILE'])) ? $this->_rootref['L_PROFILE'] : ((isset($user->lang['PROFILE'])) ? $user->lang['PROFILE'] : '{ PROFILE }')); ?></a>
						<?php if ($this->_rootref['S_DISPLAY_PM']) {  ?> (<a href="<?php echo (isset($this->_rootref['U_PRIVATEMSGS'])) ? $this->_rootref['U_PRIVATEMSGS'] : ''; ?>"><?php echo (isset($this->_rootref['PRIVATE_MESSAGE_INFO'])) ? $this->_rootref['PRIVATE_MESSAGE_INFO'] : ''; ?></a>)<?php } if ($this->_rootref['S_DISPLAY_SEARCH']) {  ?> &bull;
					<a href="<?php echo (isset($this->_rootref['U_SEARCH_SELF'])) ? $this->_rootref['U_SEARCH_SELF'] : ''; ?>"><?php echo ((isset($this->_rootref['L_SEARCH_SELF'])) ? $this->_rootref['L_SEARCH_SELF'] : ((isset($user->lang['SEARCH_SELF'])) ? $user->lang['SEARCH_SELF'] : '{ SEARCH_SELF }')); ?></a>
					<?php } if ($this->_rootref['U_RESTORE_PERMISSIONS']) {  ?> &bull;
					<a href="<?php echo (isset($this->_rootref['U_RESTORE_PERMISSIONS'])) ? $this->_rootref['U_RESTORE_PERMISSIONS'] : ''; ?>"><?php echo ((isset($this->_rootref['L_RESTORE_PERMISSIONS'])) ? $this->_rootref['L_RESTORE_PERMISSIONS'] : ((isset($user->lang['RESTORE_PERMISSIONS'])) ? $user->lang['RESTORE_PERMISSIONS'] : '{ RESTORE_PERMISSIONS }')); ?></a>
					<?php } ?>
				</li>
			<?php } ?>
				<li class="icon-faq"><a href="<?php echo (isset($this->_rootref['U_FAQ'])) ? $this->_rootref['U_FAQ'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_FAQ_EXPLAIN'])) ? $this->_rootref['L_FAQ_EXPLAIN'] : ((isset($user->lang['FAQ_EXPLAIN'])) ? $user->lang['FAQ_EXPLAIN'] : '{ FAQ_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_FAQ'])) ? $this->_rootref['L_FAQ'] : ((isset($user->lang['FAQ'])) ? $user->lang['FAQ'] : '{ FAQ }')); ?></a></li>
				<?php if (! $this->_rootref['S_IS_BOT']) {  if ($this->_rootref['S_DISPLAY_MEMBERLIST']) {  ?><li class="icon-members"><a href="<?php echo (isset($this->_rootref['U_MEMBERLIST'])) ? $this->_rootref['U_MEMBERLIST'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_MEMBERLIST_EXPLAIN'])) ? $this->_rootref['L_MEMBERLIST_EXPLAIN'] : ((isset($user->lang['MEMBERLIST_EXPLAIN'])) ? $user->lang['MEMBERLIST_EXPLAIN'] : '{ MEMBERLIST_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_MEMBERLIST'])) ? $this->_rootref['L_MEMBERLIST'] : ((isset($user->lang['MEMBERLIST'])) ? $user->lang['MEMBERLIST'] : '{ MEMBERLIST }')); ?></a></li><?php } if (! $this->_rootref['S_USER_LOGGED_IN'] && $this->_rootref['S_REGISTER_ENABLED'] && ! ( $this->_rootref['S_SHOW_COPPA'] || $this->_rootref['S_REGISTRATION'] )) {  ?><li class="icon-register"><a href="<?php echo (isset($this->_rootref['U_REGISTER'])) ? $this->_rootref['U_REGISTER'] : ''; ?>"><?php echo ((isset($this->_rootref['L_REGISTER'])) ? $this->_rootref['L_REGISTER'] : ((isset($user->lang['REGISTER'])) ? $user->lang['REGISTER'] : '{ REGISTER }')); ?></a></li><?php } ?>
					<li class="icon-logout"><a href="<?php echo (isset($this->_rootref['U_LOGIN_LOGOUT'])) ? $this->_rootref['U_LOGIN_LOGOUT'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_LOGIN_LOGOUT'])) ? $this->_rootref['L_LOGIN_LOGOUT'] : ((isset($user->lang['LOGIN_LOGOUT'])) ? $user->lang['LOGIN_LOGOUT'] : '{ LOGIN_LOGOUT }')); ?>" accesskey="x"><?php echo ((isset($this->_rootref['L_LOGIN_LOGOUT'])) ? $this->_rootref['L_LOGIN_LOGOUT'] : ((isset($user->lang['LOGIN_LOGOUT'])) ? $user->lang['LOGIN_LOGOUT'] : '{ LOGIN_LOGOUT }')); ?></a></li>
				<?php } ?>
		<?php if ($this->_rootref['S_BOARD_DISABLED'] && $this->_rootref['S_USER_LOGGED_IN'] && ( $this->_rootref['U_MCP'] || $this->_rootref['U_ACP'] )) {  ?>
				<strong><?php echo ((isset($this->_rootref['L_INFORMATION'])) ? $this->_rootref['L_INFORMATION'] : ((isset($user->lang['INFORMATION'])) ? $user->lang['INFORMATION'] : '{ INFORMATION }')); ?>:</strong> <?php echo ((isset($this->_rootref['L_BOARD_DISABLED'])) ? $this->_rootref['L_BOARD_DISABLED'] : ((isset($user->lang['BOARD_DISABLED'])) ? $user->lang['BOARD_DISABLED'] : '{ BOARD_DISABLED }')); ?>
		<?php } ?>
You take an original overall_header.html.
Then, as in the install.xml is edit the file again.
Estrellita
Oh Woot for me got it up!
Thnx so much for your help :D
I'm really enjoying this PHP business ;) I will definately be taking some Tutorials to get right into it.
Cheers.
