Not a problem
Is there a way to enter html code to display an image on the portal sides between portal blocks?
I tried entering code in portal_left.html etc. It won't display. Is this possible?
Displaying Images - Solved
Re: Displaying Images
Ok... figured it out. Must be done in the root/styles/THEME_NAME/template/portal/portal_body.html file
