Board3 & PBWOW
Julies
Board3 & PBWOW
Post by Julies »
Your Portal Version: 1.0.5
I installed phpbb 3.0.5 and installed Board3 to it. Got an error:
Fatal error: Call to undefined function get_unread_topics() in /portal/block/user_menu.php  on line 62
After reading through the forums it talks how 3.0.5 isnt compatible with Board3 1.0.5. Problem is, pbwow.com theme doesnt work with 3.0.6 but somehow they got pbwow to work with Board3. I don't know what version they are using or the combination of versions between phpbb3 and Board3 but I'm not getting much a response from that site and wondered if anyone who is running that theme has an idea on what versions work properly together.
Thank you[/i]
Re: Board3 & PBWOW
If you are running phpBB 3.0.5 you need to install Board3 Portal 1.0.4.
