Boardlink: http://www.deadandwalking.com
Hello,
Portal is great, but it's not for me right now. I was wondering how I would uninstall this safely? I've already changed some snippets in a load of files. Do I just work back and delete all the things I uploaded? Will it mess up my forum database now so it won't be able to be used again?
Uninstall the portal?
Re: Uninstall the portal?
You have to redo undo all the filechanges using install.xml.
To uninstall the Database, you have to upload the install folder again, browse to /install/index.html and choose "uninstall". (delete this install folder after that)
Reason: thnx Marc ;)
Please first upload the installer again and run the uninstaller. Afterwards you can undo the filechanges using install.xml (it's undo Mike ).
Thank you so much!
ups... ^^Marc wrote:(it's undo Mike ).
