Portal load speeds
Foxy
phpBB.de User: Foxy
phpBB.com User: fujcube
Portal load speeds
Post by Foxy »
Your Portal Version: 1.0.5
Boardlink: http://www.border-forum.com
Nothing
Nothing
Since my Portal was upgraded to the latest version, my board has almost come to a standstill. It takes absolutely ages for anything to load. ANyine know what I can do to improve the load speeds?
You can login using the following:
Username: visitor
Password: visitor
Regards, fujcube
Re: Portal load speeds
I can't even access your website, so I would probably ask your hoster if I were you. ;)
Foxy
phpBB.de User: Foxy
Post by Foxy »
Thanks for the reply. I raised a ticket with my host company and this is their reply.
Thank you for contacting Online Support. Please note that since you are on a shared hosting server there can also be slow loading times due to the activity of other users on your server. This issue can be caused by the amount of content the site contains. You can improve performance by optimizing the fields and tables of your database.
See the link below:
http://dev.mysql.com/tech-resources/pre ... index.html
Please let us know if we can assist you in any other way.
Back to regular load speeds now!
Regards
