Your Portal Version: 1.0.4
Boardlink: http://www.quietlyconfident.net/forum/
Nothing, this problem has been since installation
I have maticulously gone through several of the html files in order to see any resemblance to page width
Hi there!
I recently ported (pun intended) over to your Portal system following Teksonic as he now is working with Board3 Portal on his mods. I've had it running for a little while now, and whilst I iron out details in things as I want them there is one problem I cannot seem to resolve.
As you can see going here (http://www.quietlyconfident.net/forum/), the width of the page (the 'whiteish background') is quite a bit wider than my news items and extra boxes (Recruitment and Raid Progress). I've tried playing with my banner, however it seems the problem lies elsewhere and doesn't 'auto-fit'.
I've looked all up and down in the templates and various other HTML files for any width remarks to no avail. Does anyone know? I'd imagine this is a simple case of "open overall_header.html, edit line 350" but I'm afraid I'm not familiar with this all that well.
Many thanks,
Matt
Portal width adjustment
Re: Portal width adjustment
Still drudging my way through the HTML but still yet to find anything significant to change. Any suggestions before I try other avenues?
