Can somebody get the portal to work with the Glass theme A style by DoubleJ .
I tryed i just cant get it to work. the style is based on prosilver.
I will pay to get this working.
Help with glass style.
Re: Help with glass style.
OK i got it working only with one problem.
The ceter blocks are not working right.
The text is not lineing up.
What do i need to do to fix it?
thanks
thanks
I just fixed it. I had to edit the large.css file
Hi!
i have (i think) the same problem.
that's the site:
http://www.bravotuning.it/forum/__portal.php
as you can see all the entries are not aligned, what can i do? nobody has solved that problem?
that's the site:
Hi,DaveDevil wrote:Hi!
that's the site:
please check here: Board3.de - Rules | We ask for your attention
and here: viewforum.php?f=39
and here: viewtopic.php?f=39&t=2505&p=16809&hilit=Glass#p16788Forum rules:
I had seen that topic using the search function, but there is no a solution so I have written related to this topic ...
