Ninja10R
Posts: 4 Joined: 17. January 2009 01:12
Post
by Ninja10R » 17. January 2009 01:23
Your Portal Version: 1.0.2
Boardlink: http://www.anemosclub.gr/phpbb3/
PHP Version: 3.0.4
Installed se pro template for portal and phpbb3
Not much i'm afraid
I recently installed se pro template for phpbb3 and board3 portal on a test installation (i plan to move my forum there). Not really a problem, everything works, but i wonder if someone would help me to make the headers identical (in the phpbb3 forum there is a top menu which in the portal home page doesn't show - this is a little annoying)
Partial screenshots
Another thing i just noticed, is that after i installed se pro template for the portal, your credits are right there, under the jumpbox, but they are
invisible !!! You can only tell that they exist because of the change of the cursor !!! Any thoughts ?
Posts: 1862 Joined: 3. July 2008 23:59
Post
by Mike » 20. January 2009 19:13
It seems you followed the install instructions in the xml file:
Open: styles/prosilver/template/overall_header.html
IF not $S_IN_PORTAL means that the following (code) will only show up
if you are not in the Portal.
In other Words, as long as
you are in the Portal, the navbar
wont be showed.
If you want to permanently show up the Navbar,
redo these two changes:
Add before (DELETE THIS ADDED LINE)
Add after (DELETE THIS ADDED LINE)
And the Credits are there... Did you already fixed it?
Ninja10R
Post
by Ninja10R » 22. January 2009 01:34
Yes i did fix the credits, thank you very much for your answer
Post
by Mike » 22. January 2009 03:01
Can you tell me if it works, please? (with the navbar)
Because of im quite sure, but not without a doubt
Kosmos
Posts: 20 Joined: 9. January 2008 17:40
Post
by Kosmos » 22. January 2009 13:54
Hi Mike,
i testet it, but it dosn't works.
I have clear all caches but there is no change.
thx Kosmos
Greif nach den Sternen!
Post
by Mike » 22. January 2009 17:21
Hi Kosmos.. Please tell me your Style. I try to find out why it doesnt work
(i testet prosilver yesterday, and it works there)
Are you sure, you deletet these two lines?
Kosmos
Post
by Kosmos » 22. January 2009 19:13
Hello Mike,
thanks for helping. My style is Se_pro.
I tested it again, and i really delete the two Lines, but no change.
thx Kosmos
Post
by Mike » 22. January 2009 22:01
Ok. I've tested it with the se-pro Style, and it works perfect. But you said you already cleared your caches...
hmm...
Please copy the code of your overall_header.html in a codebox. I'll take a look at your source...
Kosmos
Post
by Kosmos » 23. January 2009 12:18
Thx Mike!
<head>
{META}
phpBB style name: prosilver
Based on style: prosilver (this is the default phpBB3 style)
Original author: Tom Beddard ( http://www.subBlue.com/ )
Modified by:
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
</script>
</head>
<div id="wrap">
<div class="border-left">
<div class="border-right">
<div class="border-top">
<div class="border-top-left">
<div class="border-top-right">
<div class="inside" style="direction: {S_CONTENT_DIRECTION}; ">
<div id="page-header">
<div class="header-bar">
<div id="board-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<div id="menu">
<div id="menu_corner"></div>
<ul>
<li class="menu_button"><a href="{U_INDEX}"><span>{L_INDEX}</span></a></li>
<li class="menu_button"><a href="{U_FAQ}"><span>{L_FAQ}</span></a></li>
<!-- IF S_DISPLAY_SEARCH -->
<li class="menu_button"><a href="{U_SEARCH}"><span>{L_SEARCH}</span> {S_SEARCH_HIDDEN_FIELDS}</a></li>
<!-- IF not S_IS_BOT -->
<!-- IF S_DISPLAY_MEMBERLIST --><li class="menu_button"><a href="{U_MEMBERLIST}"><span>{L_MEMBERLIST}</span></a></li><!-- ENDIF -->
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li class="menu_button"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<li class="menu_button"><a href="{U_LOGIN_LOGOUT}"><span>{L_LOGIN_LOGOUT}</span></a></li>
<div id="menu_corner_right"></div>
<div id="top-search">
<fieldset>
<input name="keywords" class="search-input" id="keywords" type="text" maxlength="128" title="{L_SEARCH_KEYWORDS}" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" />
</fieldset>
</form>
<li class="icon-home"><a href="{U_PORTAL}">{L_PORTAL}</a> » <a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<li class="icon-ucp">
<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a>
<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF --> •
<!-- IF U_RESTORE_PERMISSIONS --> •
</li>
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li class="icon-register"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<div id="page-body">
Ninja10R
Post
by Ninja10R » 23. January 2009 12:41
Mike wrote: Can you tell me if it works, please? (with the navbar)
I really don't know yet, i uninstalled the test board-forum and i've only installed the real forum so far. Next thing is to install bord3 portal and try this out.
Post
by Mike » 23. January 2009 14:44
@ Kosmos:
As i can see, the line
<!-- IF not $S_IN_PORTAL or not S_DISPLAY_MAINMENU --> is still in your code, though you told you deleted it
Take the following code instead of yours:
<head>
{META}
Modified by:
// <![CDATA[
if ({S_NEW_PM})
* Find a member
return false;
</script>
</head>
<div id="wrap">
<h1>{SITENAME}</h1>
<div id="menu">
<ul>
<fieldset>
</fieldset>
</form>
</li>
Ninja10R
Post
by Ninja10R » 23. January 2009 20:31
Yes, it worked. The portal is up and running.
Thanks man...
Kosmos
Post
by Kosmos » 25. January 2009 22:40
*lol* I'm stupid.
Thank you Mike, with your code it works perfect.
Post
by Mike » 25. January 2009 23:02
No problem Guys... Im glad to help you...
Blind Dragon
Posts: 7 Joined: 26. January 2009 04:09
phpBB.com User: Blind Dragon
Post
by Blind Dragon » 31. January 2009 03:00
What about for subsilver based templates? I just skipped the overall header edits and think it worked out ok
