Your Portal Version: 1.0.2
I want to Upgrade from phpBB3portal to Board3portal
What Database quereis (or tables) should be removed from my database ?
Upgrade to Board3 from phpBB 3 portal
Re: Upgrade to Board3 from phpBB 3 portal
This should all be done by the board3 Portal installer automatically.
So I must only upload a fresh copy of phpBB that installed Board3 on it then run board3 installer and all db needs done ?
Open update_phpbb3portal_110b.xml or update_phpbb3portal_122.xml - depending on which version you have been using - with your webbrowser.
I was removed phpbb3portal modificated phpbb and now use a modificated by board3portal phpBB,Now what should I do ?
I need only SQL changes
Run the installer.
Ok,thanks alot
