How to change "link to us"?
Boardlink: http://www.karapatis.com/forum
PHP Version: 3.02
The root of my forum is mysite/forum and not mysite/phpbb. how can i change this??????
PHP Version: 3.02
Re: How to change "link to us"?
This depends on a misconfiguration of your board. Set the correct script path in your ACP:
Server-configuration --> Server and Domain --> Script-path
thnxxxx
Id like this link to point at my home page (the portal page). I tried deleting the phpbb3 from the script path and it just puts phpbb3 back anyway. How can i get the link to point at my home page?Kevin wrote:This depends on a misconfiguration of your board. Set the correct script path in your ACP:
I want to make my own text
How can I do it?
How can I do it?
open: root/language/en/mods/lang_portal.php
search for: (line 167)
... and replace with
'LINK_US_TXT' => 'Please feel free to link to <strong>%s</strong>. Use the following HTML:',Code: Select all
'LINK_US_TXT' => 'what ever you want',kein Support per PN / Messenger
thanks for answer
but I want to change the link (html)
sorry for my english
Currently the link is created from phpbb variables, but on some installations it goes a bit weird. To manually change the link look through /portal/block/link_us.php
I've looked through this file. I understand PhP to a very limited degree. I looked through, what it says makes sense to me. I can pick it apart, but I have no idea how to add in my own code. All I want to do instead is make it basically do this:Ice wrote:Currently the link is created from phpbb variables, but on some installations it goes a bit weird. To manually change the link look through /portal/block/link_us.php
<a href="website"><img src="mybutton"></a>Edit: nvm, I think I'm just going to try and make myself a much less complicated block...
Edit2: Now I see why it's so complicated -_-
I'm so close I can taste it. I'm just having one problem, which is getting the actual link into the quotations, but damn, I think I'm doing alright for not really knowing anything about this. This is my code:
That's line 29 of portal/block/link_us.php
If anyone could help me, I'd very much appreciate it
'U_LINK_US' => '<a href="' . $u_link . '" ' . (($config['site_desc']) ? '<img src="' . $config['http://www.buttonlink.com/images/img.gif'] . '"' : '' ) . '>' . (($config['sitename']) ? $config['sitename'] : $u_link ) . '</a>',
This worked, I had to change the $u_link path but it worked. Thank you very much, really appreciate the help
