directly to portal
tatzel
directly to portal
Post by tatzel »
Your phpBB Version: 2.0.
I installed the forum and the portal in the same directory (/root). How do i adapt my files so when you enter www.mysite.com, it goes straight to portal.php instead of index.php? been searching for a solution, but i can seem to find one. thanks in advance
scwfan06
phpBB.de User: scwfan06
phpBB.com User: scwfan06
Re: directly to portal
Post by scwfan06 »
Hi tatzel
Open: .htaccess
Find:
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Add after in a new line:
tatzel
Post by tatzel »
did that. didnt work....
tatzel
Post by tatzel »
I solved this now.
# $Id: .htaccess,v 1.2 2007/04/12 06:19:39 angelside Exp $
# .htaccess for phpBB3 Portal
DirectoryIndex bb3portal.php index.php
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
Order Allow,Deny
Deny from All
</Files>
is my .htaccess atm.
changing bb3portal.php at the top into portal.php solved it.
WeeTjeSSS
Post by WeeTjeSSS »
Hello,
I have a problem,
If I am on Board index,
do not be possible I to Portal.
But if I am on Portal am possible
I, however, to Board index…
Help me please
http://forum.goldenhabbos.nl
Sorry for my English I'm Dutch ;)
You may have missed this during installation:
Open: includes/functions.php
'U_PRIVATEMSGS'            => append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&folder=inbox'),
'U_PORTAL'                => append_sid("{$phpbb_root_path}portal.$phpEx"),
WeeTjeSSS
Post by WeeTjeSSS »
He cannot find
This are my functions I have edit php to txt, now can you see...)
http://forum.goldenhabbos.nl/board3/functions.txt
Search for:
WeeTjeSSS
Post by WeeTjeSSS »
Sorry for my Stopid Questions!
I have fix ;)
Thanks for you help!
Greez,
Dylan
