Your Portal Version: 2.0.0
Boardlink: http://alwaysfunkilling.com
MySQL Version: Problem with layout of board index and portal.
edited absolution for board3 portal using the instructions on forum.
Retried it.
Hello,
So i followed the instructions that i need to edit for absolution , everything went well and the portal button is there , but now it shows an external board index but in normal letters without a button.
Would appreciate any help!
Kind Regards,
Lukas
Absolution
Re: Absolution
Actually not a portal problem. Anyways, I'd remove this if I were you from navbar.html:
Obviously the second one.
<a href="{U_INDEX}"><img src="{T_THEME_PATH}/images/nav-home.png" width="16" height="16" alt="" />{L_INDEX}</a>
Re: Absolution
