Reading hte forum and KB.
This is a question that probably seems stupid, but I haven't been able to figure it out, so...
Do the changes listed in the information for the style options always, never or sometimes need to be done "by hand", or will the style authomaticly be reflected also on the portal?
Installing new style - but how?
- Sponsor
- phpBB.de User: cpg
Re: Installing new style - but how?
download your style
unpack
upload the folder to your site into: phpBB3/styles/
You find there the standard-folder (prosiver, subsilver2)
Than you can - in your admin-center in STYLES
install the new one
Regards
CPG
download your style
unpack
install the new one
Regards
CPG
Thank you, cpg. But I must have missed something...? I did as you say:
*unpacked the zip to my desktop
*uploaded the folder to the portal>styles (where prosilver and subsilver already are as standard
*the new style is now listed in the ACP>style
*refreshed template, themes ans imageset (the new style)
*purged the cache under "general".
When I entered the site the new style is installed on the board...but no link or sign to/of the portal. Hovever this error/warning displays:
Actually I do understand what is tells, but have no idea how to fix it
Information
The requested file could not be found: styles/art_black/theme/images/portal/
- phpBB.de User: Graaft
- phpBB.com User: Graaft
you have to follow the portal install instructions for the prosilver/subsilver style for your new style..
check on which one your new style is based and follow the install instructions
should work then
should work then
See it here ==> viewtopic.php?f=57&t=5418eita wrote:Thank you, cpg. But I must have missed something...? I did as you say:
When I entered the site the new style is installed on the board...but no link or sign to/of the portal. Hovever this error/warning displays:Actually I do understand what is tells, but have no idea how to fix itCode: Select all
Information The requested file could not be found: styles/art_black/theme/images/portal/
Thank you, all of you. I figured it out, was very confused in thee beginning because I didn't understand if all the changes listed in the documentation was supposed to be done. When I finaly understood it was only those listed to be copied from the extracted download it was no problem.
GREAT portal, by the way.
