Hi!
after the install of board3_portal_2_0_0b1 i get nothing on my root/portal.php !!
just a blank page with the word "bloc" in the top left corner
i have the same error in the acp when i clic on the "Portal Modules" link
my local site runs on wamp server 2.0 (php 5.3.0)
see what i get on this image => http://hebergeurimage.free.fr/nothing_o ... 182335.jpg
any idea ??
[SOLVED]Blank page on portal.php
Topic author - Translator
- phpBB.com User: pokyto
Re: Blank page on portal.php
A link to the Board would be helpful.
yes i know but this is a work in progress site, and for now only in local ... my actual site runs online/local with board3_portal_1_0_6 perfectly !!archivar wrote:A link to the Board would be helpful.
edit : well !! i give up! the more i search the less i understand where is the error!!
i'll wait for the release instead of trying with a beta
Hi!!
I uploaded a fresh install of phpbb 3.0.9 + board3 2.0.0b1
i get the same error as previously, online and in local
you can see what i get on this test URL => http://essai.lestontonsfraggers.com
i can send you by MP login and password of the admin account ... i really don't understand what i'm doing wrong !!??
Thx !
Edit: i think i found the problem ... the error appears when i turn on the french language in my profil or/and in the general settings,
if i turn back the forum on english or german there is no error !
Thx !
Remove this code in all standard French language files *. php files on the final of the portal v. 2b1:
in last line:
![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
in last line:
Refresh your Styles:
nope! it doesn't change the problem, i always have a blank page on the portal if i set "french" as default language even after the changes
i also made the changes online if you want to check
i think i found an other mistake in the french transalation files in root\language\fr\mods\portal\portal_whois_online_module.php
there is a "bloc" just before "<?php" .. first line .... but with or without this word the error persists
bloc<?php
* @package Board3 Portal v2 - Who is online
* @translated by anywhere91 for zone-bf.com
* DO NOT CHANGE
Done !
line 42 of root/language/fr/mods/portal/portal_latest_members_module.php
missing quotes before the semicolon at the end of the string !!
with this string
that works !!
Thank you very much for your expertise and your patience !!
Warning: Unexpected character in input: ''' (ASCII=39) state=1 in /home/hosted/usersSpace/17/ftp/lestontonsfraggers.com/essai/language/fr/mods/portal/portal_latest_members_module.php on line 42
Parse error: syntax error, unexpected T_STRING, expecting ')' in /home/hosted/usersSpace/17/ftp/lestontonsfraggers.com/essai/language/fr/mods/portal/portal_latest_members_module.php on line 42
'PORTAL_MAX_LAST_MEMBER_EXP' => '0 signifie infinis,
with this string
'PORTAL_MAX_LAST_MEMBER_EXP' => '0 signifie infinis',
