Fresh Install - overall_header.html Error
typica1cat
Post by typica1cat »
Boardlink: http://dailyentity.com.s50044.gridserver.com/
Google searches - no avail.
Trial and error with no success.
I just installed a fresh version of phpbb3 With no problems. I decided to go with the Afterburner RocketTheme. All of my edits per the instructions worked perfectly except one Instruction:
CODE:SELECT ALL
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong>
CODE:SELECT ALL
CODE:SELECT ALL
This theme is a bit different from normal themes using entire CSS Stylizing. I was wondering if someone here could help me figure this bit out. Here is the overall_header.html file:
<head>
{META}
<!-- IF S_ENABLE_FEEDS -->
<!-- INCLUDE afterburner_config.html -->
	phpBB style name: afterburner
	Based on style:   prosilver (this is the default phpBB3 style)
	Modified by: RocketTheme, LLC (C) Copyright. All rights reserved.
// <![CDATA[
	var on_page = '{ON_PAGE}';
	var per_page = '{PER_PAGE}';
	<!-- IF S_USER_PM_POPUP -->
		if ({S_NEW_PM})
			var url = '{UA_POPUP_PM}';
	* Find a member
	function find_username(url)
		return false;
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
<script type="text/javascript" src="{T_SUPER_TEMPLATE_PATH}/forum_fn.js"></script>
<!-- IF $SHOW_AFTER_FONT -->
<script type="text/javascript" src="{T_SUPER_TEMPLATE_PATH}/styleswitcher.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/mootools-release-1.11.js"></script>
<link href="{T_THEME_PATH}/small.css" rel="alternate stylesheet" type="text/css" title="A--" />
  <style type="text/css">
	#wrapper { margin: 0 auto; width:{$AFTER_WIDTH};padding:0;}
	.s-c-s #colmid { left:210px;}
	.s-c-s #colright { margin-left:-210px;}
	.s-c-s #col1pad { margin-left:210px;}
	.s-c-s #col2 { left:0px;width:210px;}
	.s-c-s #col3 { width:0px;}
	.s-c-x #colright { left:{$AFTER_SIDECOL_WIDTH};}
	.s-c-x #col1wrap { right:{$AFTER_SIDECOL_WIDTH};}
	.s-c-x #col1 { margin-left:{$AFTER_SIDECOL_WIDTH};}
	.s-c-x #col2 { right:{$AFTER_SIDECOL_WIDTH};width:{$AFTER_SIDECOL_WIDTH};}
	.x-c-s #colright { margin-left:-{$AFTER_SIDECOL_WIDTH};}
	.x-c-s #col1 { margin-left:{$AFTER_SIDECOL_WIDTH};}
	.x-c-s #col3 { left:{$AFTER_SIDECOL_WIDTH};width:{$AFTER_SIDECOL_WIDTH};}
	<!-- IF $AVATAR_POSITION == left -->
	.postprofile {float: left; border: 0px; margin-left: -6px;}
	.postbody {float: right;}
	ul.profile-icons {margin-right: 40px;}
	.online {background-position: 17% -1%;}
	<!-- IF $AFTER_MENUPOSITION == left or $AFTER_MENUPOSITION == right -->
#postingbox .autowidth {width: 90% !important; }
	#postingbox .column2 { width: 75%; margin-top:-65px; position: relative;}
	#postingbox .column1 { width: 70%;position: relative; z-index:10000;}
	#postingbox fieldset.fields1 dd { margin-left: 15em;}
	#colour_palette dd { margin-left: 6em !important;}
  </style>
    <!--[if IE 6]>
  #postingbox .column2 { width: 75%; margin-top:0px; position: relative; margin-left: -300px;}
   </style>
  <![endif]-->
  <!--[if IE 7]>
  #postingbox .column2 { width: 75%; margin-top:0px; position: relative; margin-left: -300px;} #message-box #message {width: 98%;} #cp-main {width:80%;}
   </style>
  <![endif]-->
<link rel="stylesheet" href="{T_THEME_PATH}/{$AFTER_STYLE}.css" type="text/css" />
<!--[if lte IE 6]>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/ie_suckerfish.js"></script>
<link href="{T_THEME_PATH}/styles.ie.css" rel="stylesheet" type="text/css" />
<![endif]-->
<!--[if lte IE 7]>
<link rel="stylesheet" href="{T_THEME_PATH}/styles.ie7.css" type="text/css" />
<![endif]-->
<!-- IF $ROK_IMAGESET_SWITCHER -->
<!-- IF $AFTER_STYLE eq 'dark' or $AFTER_STYLE eq 'dark2' or $AFTER_STYLE eq 'dark3' or $AFTER_STYLE eq 'dark4' -->
// <![CDATA[
window.addEvent('domready', function() {
  var newImagePath = '{ROOT_PATH}/styles/afterburner_dark_imageset/imageset/'; // remember to add the ending forward slash
  var classToSearch = '.icon';
  var els = $$(classToSearch);
  if (els.length) {
    els.each(function(el) {
      var bg = el.getStyle('background-image'), newBg, imgSource;
      bg = bg.replace('")', '').replace(")", '');
      var tmp = bg.split('/');
      imgSource = tmp[tmp.length - 1];
      el.setStyle('background-image', 'url('+newImagePath+imgSource+')');
</script>
</head>
<body id="phpbb" class="<!-- IF $AFTER_STYLE eq 'dark' or $AFTER_STYLE eq 'dark2' or $AFTER_STYLE eq 'dark3' or $AFTER_STYLE eq 'dark4' -->dark <!-- ENDIF -->section-{SCRIPT_NAME} {S_CONTENT_DIRECTION}">
<div class="background"></div>
<div id="main">
	<div id="wrapper" class="foreground">
	    <div id="header">
    	    <a href="<!-- IF $AFTER_LOGO_LINK -->{$AFTER_LOGO_LINK}<!-- ELSE -->{U_INDEX}<!-- ENDIF -->"><span id="logo"></span></a>
		<div id="nav">
									 <ul class="menutop">
<li class="item1 <!-- IF SCRIPT_NAME eq 'index' -->active<!-- ENDIF --> root"><a class="orphan item" href="{U_INDEX}" accesskey="h"><span>{L_INDEX}</span></a></li>
<li class="item2 <!-- IF SCRIPT_NAME eq 'ucp' -->active<!-- ENDIF --> root"><a class="orphan item bullet" href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u"><span>{L_PROFILE}</span></a></li>
<li class="item3 <!-- IF SCRIPT_NAME eq 'faq' -->active<!-- ENDIF --> root"><a class="orphan item bullet" href="{U_FAQ}" title="{L_FAQ_EXPLAIN}"><span>{L_FAQ}</span></a></li>
<li class="item2 <!-- IF SCRIPT_NAME eq 'memberlist' -->active<!-- ENDIF --> root"><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}" class="orphan item bullet"><span>{L_MEMBERLIST}</span></a></li>
<!-- IF not S_IS_BOT -->
<li class="item4 <!-- IF S_UCP_ACTION eq './ucp.php?mode=register' -->active<!-- ENDIF --> root"><a class="orphan item bullet" href="{U_REGISTER}"><span>{L_REGISTER}</span></a></li>
<li class="item5 <!-- IF S_DISPLAY_FULL_LOGIN -->active<!-- ENDIF --> root"><a class="orphan item bullet" href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l"><span>{L_LOGIN_LOGOUT}</span></a></li>
		<div id="message">
        <div id="main-content" class="<!-- IF $AFTER_MENUPOSITION == left -->s<!-- ELSE -->x<!-- ENDIF -->-c-<!-- IF $AFTER_MENUPOSITION == right -->s<!-- ELSE -->x<!-- ENDIF -->">
            <div id="colmask" class="ckl-{$AFTER_COLUMN_COLOR}">
                <div id="colmid" class="cdr-{$AFTER_COLUMN_COLOR}">
                    <div id="colright" class="ctr-{$AFTER_COLUMN_COLOR}">
                        <div id="col1wrap">
							<div id="col1pad">
                            	<div id="col1">
									                                    <!-- IF $SHOW_AFTER_PATHWAY -->
													    <div class="breadcrumbs-pad">
                                        <div class="breadcrumbs">
<a href="{U_INDEX}" accesskey="h" class="pathway">{L_INDEX}</a> <!-- BEGIN navlinks --> <span class="sep">\</span> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks -->
                                    </div><!-- ENDIF -->
																		                                    <div class="component-pad">
<div id="page">
<div id="wrap">
	<div id="page-header">
	<!-- IF $AFTER_MENUPOSITION == full -->
			<div class="inner">
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="fontsizeup(); return false;" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li><!-- ENDIF -->
				<li class="icon-ucp">
					<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{L_PROFILE}</a>
						<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF -->
					<!-- IF S_DISPLAY_SEARCH --> &bull;
				</li>
					<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><li class="icon-register"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
			<ul class="linklist ">
				<!-- IF $SHOW_AFTER_FONT --><li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="fontsizeup(); return false;" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li><!-- ENDIF -->
	<div id="page-body">
		<div id="information" class="rules">
Any help would be greatly appreciated! Thanks in advance![/i]
Re: Fresh Install - overall_header.html Error
the style "Afterburner" is not suitable for the portal.
The style for the portal is much work to adapt.
Look if you can find an alternative style for the portal.
typica1cat
Thank you very much for the swift reply - I do appreciate it. I will look around.
Thanks again!
typica1cat wrote:Thank you very much for the swift reply - I do appreciate it. I will look around.
Thanks again!
Look here: viewforum.php?f=47 + viewforum.php?f=44
Return to “Styles Support”
