Boardlink: http://forums.prats-uk.org/portal.php
Installed Portal
very little
Now that I have this excellent Portal installed I would like to make it the default landing page for my site and for all the newly registered users. What do I need to do to achieve this? Currently the landing is on index.php I need it to be portal.php
Making the Prtal the default landing page
the wolfman
Re: Making the Prtal the default landing page
Make sure you edited .htaccess as instructed by install.xml. If that doesn't work, you will have to contact your hoster.
the wolfman
The instructions are your friend!Marc wrote:Make sure you edited .htaccess as instructed by install.xml. If that doesn't work, you will have to contact your hoster.
Thanks, it's so easy when you get the nudge in the right direction.
