The settings in ACP isnt there...
frold
Portal Enthusiast
Post by frold »
Hey,
Where in the ACP should I be able to find the portal settings?
Re: The settings in ACP isnt there...
In the tab called "mods".
frold
Portal Enthusiast
Post by frold »
Kevin wrote:In the tab called "mods".
There is no such tab....
Cleared your cache? Executed the installer?
frold
Portal Enthusiast
Post by frold »
Kevin wrote:Cleared your cache? Executed the installer?
Yep...
I run a plain phpBB3 and this mods - that is it...
frold
Portal Enthusiast
Post by frold »
Do I need to install phpbb3portal first?
No, no!
And you can see the portal?
Have you done the changes from the install.xml? And excecuted the portal installer in install_portal?
Do you have a link to your forum?
frold
Portal Enthusiast
Post by frold »
Kevin wrote:No, no!
Yep I should have do onne in install.xml and did exececute the installer I have phpbb_portal_config in the database
Ah, okay. The portal looks like everthing is okay.
You still can't see the ACP tab "mods" with the portal settings included? Purged the cache again?
Can you see the modules in the ACP Area Sytem/Module management/Administration Control Panel?
Hm, you could try to run the installer again, unistall the portal, run the installer again and reinstall the portal.
frold
Portal Enthusiast
Post by frold »
Kevin wrote:Ah, okay. The portal looks like everthing is okay.
I did so - and I still dont have a MOD tab - when I look in the schema_data - I can see it only affect phpbb_portal_config and not phpbb_modules....
frold
Portal Enthusiast
Post by frold »
Now its there!!
I dont know what was wrong...
calproye
Translator
Post by calproye »
Well, I've got the same problem :( . I finished the Spanish translation for 1.0.0 RC1 and the portal works fine :) ( you can look on http://www.portal.calproye.es/ , but the ACP doesn't work properly :( .
I've got the "mod" tab, and the father portal and sub modules, but when I click on MOD tab, then I get a blank page: ( I haven't got any error page, only blank screen
I can't access to the ACP of this portal ( I've tested phpBB3 Portal 1.2.2 and it works fine, but this one not )
¿Any ideas?
Thanks in advanced and Regards
calproye
Translator
Post by calproye »
calproye wrote:Well, I've got the same problem :( . I finished the Spanish translation for 1.0.0 RC1 and the portal works fine :) ( you can look on http://www.portal.calproye.es/ , but the ACP doesn't work properly :( .
¿Any ideas?
I caught the problem: my Spanish translation :oops:
I copied from /en all files to /es and the portal ACP works fine
I have to revisited my sintax translation
Best Regards
