Installing Board3 v1.0.5 on phpBB 3.0.7-PL1
Repoman
Post by Repoman »
Your Portal Version: 1.0.5
Boardlink: localhost
Just a fresh install of phpBB 3.0.7-PL1
Search the forums on Board3 and phpBB
Hi all,
Is there any info available whether 1.0.5 is compatible with version 3.0.7-PL1 of phpBB?
I installed a fresh install of phpBB on my pc using EasyPHP and tried to install Board3 portal.
Everything goes fine until I need to run the installer script.
As soon as I point my browser towards install/index.php there is no option to install the portal and only shows the option to convert and some links for support.
Anybody here with a similar problem or has a fix for this?
Thanks in advance,
Re: Installing Board3 v1.0.5 on phpBB 3.0.7-PL1
Sounds to me like you had phpbb3portal installed, otherwise you wouldn't get that. Try running convert and see what you get.
Repoman
Post by Repoman »
Thanks for the fast reply.
When i start the conversion i get the following message:
127.0.0.1/forum/install/index.php?mode=convert&sub=create_table
Fatal installation error
index.php [ 273 ]
Module "" not accessible.
Repoman
Post by Repoman »
Seems that after a refresh of the page the conversion completed without errors.
The portal is working fine now.
Thank you for the help
