The Team Block - Change to user defined
Chef_uk
phpBB.com User: Chef_uk
Post by Chef_uk »
Your Portal Version: 1.0.5
Checked on here, saw thread but hasn't helped
see above
How can i change "The Team" from showing the Administrators to one of my user definded groups?
Extended Leaders / Team: is ticked yes.
And i have tried to edit the block changing ADMINISTRATORS to my usergroup but to no avail
// Admin group id...
$sql = 'SELECT group_id
	FROM ' . GROUPS_TABLE . "
	WHERE group_name = 'CLAN_COUNCIL'";
$admin_group_id = (int) $db->sql_fetchfield('group_id');
$db->sql_freeresult($result);
[/i]
Chef_uk
Re: The Team Block - Change to user defined
Post by Chef_uk »
Any ideas on the above, nothing i'm doing is changing it from the Administrators?
EDIT: Fixed, I had to first add the user defined group to the legend. Then make the group the default for each member in that group. The administrators group was still showing so to get rid of that, i had to untick it from showing in the legend. This may not suit everyone as they like to have administrators in the legend but its how to get a user defined group to show in the block "
Finally how do i go about adding custom mini icons for new blocks that reside in theme/images/portal? I've tried copying the code from existing blocks but it completely screws up the portal layout. If i can fix these last two issues i will be done :)
EDIT: Fixed again, i'm on a roll :) I must have missed a character somewhere as after searching again i found i was on the right path adding <!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/IMAGE_NAME_HERE" width="16" height="16" alt="" />&nbsp;<!-- ENDIF --> to said block html file but this time it worked flawlessly.
Site is now ready to go, once i've compiles a full back up of everythign i shall go post it in the show your portal forum for the world to see :)
