Install Script issue
Azrhei
Post by Azrhei »
Your Portal Version: 1.0.5
Boardlink: http://slaveway.org
PHP Version: 3.0.6
MySQL Version: 5.0.45
nothing....didn't notice until I wanted to edit links
Uninstalled and reinstalled portal. (Used AutoMod)
After installing it instructs to visit mysite.com/install/index.php. When doing this, the only option I have is uninstall. I have no control panel for the portal (I even tried to manually create but never shows up)
6Maverick6
phpBB.com User: 6Maverick6
Re: Install Script issue
Post by 6Maverick6 »
i believe Automod is the issue here.
I also done that and it didn't work i uninstalled it though but i left edits in the files so i had to manually remove them and add them manually but still have the missing ACP stuff.
*Just remembered i 2 also used Automod at the start*
Have you tried running Uninstall and afterwards running Install?
