Please a help installing portal with another style
Hi i need some asistence installing this portal with http://demo.phpbb3styles.net/X-Treme i have a lot time trying and nothings i really apreciate if someone can help, of course only if someone really want help me thanks and your portal is cool
Re: Please a help installing portal with another style
Have you already tried this theme with our subsilver2 template?
The X-Treme Style seems to base on subsilver2.
yes but i dont found this in the theme
<div id="menubar">
We need a link to the overall_header.html as TXT file or at least a link to your forum.
mmm after all i install the portal but was not good i think the theme need some modification to work with portal and i cant use my launguae (spanish) i can try translating i hope you can try the portal with that theme http://demo.phpbb3styles.net/X-Treme
I won't install a style just for a single support question.
Kevin wrote:We need a link to the overall_header.html as TXT file or at least a link to your forum.
- phpBB.de User: PeterS
- phpBB.com User: PeterS
Hallo Kevin,
hier ist der Link zur Overall-Header Style Extreme, unbearbeitet
http://test.wirueber40.de/overall_header.txt
gruß Peter
gruß Peter
Looks to me as Peter already has done the changes to the overall_header.html
Hi Kevin,
sorry thats was wrong, now ist correct
Greetz Peter
Greetz Peter
so with this changes the portal should work right? and other question am using spanish translation for the forum but its seems is not compatible with the default language english so how can i make my own portal translation what files i need modify?
- Valued Contributor
- phpBB.de User: HenK
- phpBB.com User: H3nK
Take a look at here:bio wrote:so with this changes the portal should work right? and other question am using spanish translation for the forum but its seems is not compatible with the default language english so how can i make my own portal translation what files i need modify?
viewtopic.php?f=11&t=144
and here, I think (?):
viewtopic.php?f=11&t=291
Additional to Henks post:
If you do all the work with the spanish translation, it would bee nice if you share your work with others who need the spanish language files.
If you join the group "Translators", you would be able to upload the files. I'll add them to the SVN.
Thank you!
Thank you!
OK i gonna translate it i think is not too complicated
