Portal display CSS something missing
jinbatsu
phpBB.com User: JinYoshi
Post by jinbatsu »
Your Portal Version: 1.0.4
Boardlink: http://www.nurmadinah.com/forum/
Just installing the Portal with manual, step by step with default theme (prosilver).
- refresh all type style , purge cache, just like what the installation suggest.
- Delete chache files from ACP
- Delete chache files from the file system under folder my /forum/cache/ excapt index.html and .htaccess
Please take a look at http://www.nurmadinah.com/forum/portal.php
The Navigation Menu UL and LI, that look like not loaded the correct css or missing small class or something like that..
I'm using phpBB 3.0.6
Thank you.
Re: Portal display CSS something missing
It seems to me that your theme cache has not been refreshed properly. Please do this again.
jinbatsu
Post by jinbatsu »
OK it works..
but another question..
what should I do for getting the permanent style theme css?
1. I want to change 2 files, common.css and colours.css under folder /forum/styles/prosilver/theme/
2. and upload/replace to /forum/styles/prosilver/theme/
3. and ACP->General->purge chache
4. and ACP->Style->Themes->Subsilver->Refresh
It doesn't work..
The background color is not white and the width is not fixed anymore..
Please help.
Thanks.
jinbatsu
Post by jinbatsu »
well ok solved and it works..
i just must the browser also clear the cache..
well thanks alot for the good Portal MOD. :ugeek: :mrgreen:
