[SOLVED] Error on install to 1.0.4
bearqst
phpBB.com User: bearqst
Post by bearqst »
Your Portal Version: 1.0.0
Boardlink: http://www.snowtravelers.org
Searched site
Double checked code and install.xm_
Just completed a fresh install of Board3 Portal 1.0.4 and now get
Parse error: syntax error, unexpected T_BOOLEAN_AND in E:\Inetpub\Snowtravelers\phpBB3\includes\session.php on line 1590
I double checked the code on that line, whcih the install says should be
[includes/session.php
Code:Select all
if (!empty($_GET['style']) && $auth->acl_get('a_styles'))
Code:Select all
if (!empty($_GET['style']))
I have
What am I missing or ?
TIA[/i]
Re: Error on install to 1.0.4
Could you put a copy of your session.php in a zip-file and upload it here?
bearqst
Post by bearqst »
Sure, how ? I have it zipped, but don't see an option to upload a file ?
bearqst
Post by bearqst »
Got it and got passed the error.
Now I get another message on the Update Process, this is where I ran into troule last time :)
Out-of-date files
Out-of-date files - please delete these files to avoid security issues.
language/en/mods/lang_portal_acp_logs.php: File still exists
portal/includes/functions_poll.php: File still exists
portal/includes/lang_adm_additional_blocks.php: File still exists
portal/includes/mini_cal/calendarSuite.php: File still exists
portal/includes/mini_cal/index.html: File still exists
portal/includes/mini_cal/mini_cal_common.php: File still exists
portal/includes/mini_cal/mini_cal_config.php: File still exists
portal/includes/mini_cal/mini_cal_topic.php: File still exists
styles/prosilver/template/portal/block/_sample_block_design.html
Last time (when I tried to update 1.0.2 to 1.0.3 I had to reinstall "language/en/mods/lang_portal_acp_logs.php" to get my site back up.
bearqst
Post by bearqst »
I've gotten past the initial "Please Delete" these files and now get
General Error
Language file ./../language/en/mods/lang_portal_acp_logs.php couldn't be opened.
Sorry to flood yu with these step by steps, but I figure this may help others.
OK, so I reloaded "./../language/en/mods/lang_portal_acp_logs.php"
And now I have my site back and an update Board3 Portal Ver 1.0.4.
If you followed the correct update instructions from 1.0.2 to 1.0.3, that file wouldn't exist anymore and wouldn't cause any error.
bearqst
Post by bearqst »
Then I've obviously I missed something. Where does it call "language/en/mods/lang_portal_acp_logs.ph_" and what did I miss that needs to be fixed so I can delete it. ?
Take a look at the update instructions from 1.0.2 to 1.0.3 in the download package.
shinoshi
Post by shinoshi »
i have the same problem in version 1.0.2, when i run your install.php i get this
General Error
SQL ERROR [ mysqli ]
Table 'jedon.phpbb_portal_config' doesn't exist [1146]
SQL
SELECT config_value as version FROM phpbb_portal_config WHERE config_name = 'portal_version' LIMIT 1
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
LINE: 205
FILE: includes/db/dbal.php
LINE: 170
FILE: install_portal/install.php
LINE: 51
CALL: dbal->sql_query_limit()
*laughs* just noticed the version # on this thread.. maybe i will try to find it(version 1.0.2 is the only version linked on phpbb.com)
*edit*
can't find a download link for 1.0.4
is there a fix for 1.0.2?
