CSF1
- phpBB.de User: blast
- phpBB.com User: blast
CSF1
Been searching around for a up to date style and came across this>>http://demo.phpbb3styles.net/CSF1 and i liked it very much but i saw that it was subsilver2 and i tryed to install portal onto this but failed i cant seem to get this working is there any way you could take a look at this and see if it can adapt the portal mod for me mike ?
thanks
Justin
thanks
Justin
Re: CSF1
Upload the content of the Portal 1.0.4 styles/subsilver2 folder into the styles/CSF1 folder.
Open: styles/CSF1/template/breadcrumbs.html
Open: styles/CSF1/template/overall_header.html
DIY Instructions
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
<a name="top"></a>
<div id='wrapper'>
<div id='header'></div>
<!-- IF S_DISPLAY_SEARCH and S_USER_LOGGED_IN --><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
<table class="tablebg breadcrumb" width="100%" cellspacing="{$CA_SPACING}" cellpadding="0" style="margin-top: 5px;">
</div></div></div>
<div class='menu_bot'>
<div class='menu_bot_l'>
<div class='menu_bot_r'>
</div></div></div><br>
Refresh your Styles:
Re: CSF1
Dont forget to use the Validator... http://validator.w3.org
This Style has a lot of misplaced Tags in his Header....
Re: CSF1
With this Validator you can chek if your website match the html and css Standarts. If you klick the Link you can add your URL into the Form, and hit "validate". Choose a style on your Board an copy the URL. If you check it with prosilver you should get no errors cause it is valid. If you check this Style (CSF1) you will see the the plenty of Errors into the Header...
Re: CSF1
I try to make it working, but at the moment i have not enough time since i have to work more than 12 Hours per Day
Re: CSF1
I would love to see this template also. I have been looking for a way to get this template to work with Board Portal 3. But have failed at doing it. Thanks for taking the time to make it work.
I will be checking back daily. Take your time, im in no rush. I also have been working 12 hour days for the past month. I know how you feel.
Re: CSF1
Thats what i can do for now... http://area51.mikevil.de/portal.php?style=77 (EDIT: looks ugly in IE8 )
This Style looks nice, but in every single file are much errors. Since it is not my Job to improve someones Style, you have to call the Autor for an proper version...
To correct the errors at least in the header and footer do the following steps... (there are some more in forumlist_body.html, index_body.html etc.)
open overall_header.html
find:
replace with:
find:
replace with:
find:
replace with:
open jumpbox.html
find:
replace with:
open overall_footer.html
find:
add before:
And last but not least the _block_config file
find:
<div id='nav'><div><div class='menuBar' style='width:100% style='width:100%; white-space: nowrap'>
<div id='nav'><div><div class='menuBar' style='width:100%; white-space: nowrap'>
find:
<input type="text" name="keywords" size="40" class="searchx" value="{L_SEARCH} ..." onFocus="if
(this.value==this.defaultValue) this.value='';"/>
<input type="text" name="keywords" size="40" class="searchx" value="{L_SEARCH} ..." onfocus="if(this.value==this.defaultValue) this.value='';"/>
find:
</div></div></div><br />
open jumpbox.html
find:
</form>
</form>
find:
</body>
</html>
<!--version $Id: _block_config.html 553 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="menu_top"><div class="menu_top_l"><div class="menu_top_r"><h3 style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3></div></div></div><div class="m_l"><div class="m_r"><div class="menu_text" style="padding: 3px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div><div class="menu_bot"><div class="menu_bot_l"><div class="menu_bot_r"></div></div></div><br />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="menu_top"><div class="menu_top_l"><div class="menu_top_r"><h3>' -->
<!-- DEFINE $C_BLOCK_H_R = '</h3></div></div></div><div class="m_l"><div class="m_r"><div class="menu_text" style="padding: 3px;">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div></div><div class="menu_bot"><div class="menu_bot_l"><div class="menu_bot_r"></div></div></div><br />' -->
Re: CSF1
Ya i check it and could not find a problem. Then i re-did it all again.
I dont think you missed it, From looking at your test site mike. Must be something that I am doing wrong.
Ill try again when I get some free time.
Thanks for all the help. As always
Re: CSF1
The edits i postet above are just for fixing the Header. To hide the phpbb Menu or add the portal button the are few more addings needed.
Since i sadly have no time at the moment, i just can post my own overall_header.html. You can replace it with yours, to get the same look...
Make a backup of you own Header as first!
<head>
<!-- INCLUDE ca_config.html -->
<meta name="copyright" content="2002-2006 phpBB Group" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!--[if IE]>
<link rel="stylesheet" type="text/css" href="{T_THEME_PATH}/ie7.css" />
<![endif]-->
// <![CDATA[
var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
<link rel="stylesheet" href="{T_THEME_PATH}/style.css" type="text/css" />
</head>
<a name="top"></a>
<div id='wrapper'>
<!-- IF U_PORTAL --><a class='menuButton' href="{U_PORTAL}">{L_PORTAL}</a><!-- ENDIF -->
<a class='menuButton' href="{U_INDEX}">{L_INDEX}</a>
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN --><a class='menuButton' href="{U_PROFILE}">{L_PROFILE}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a class='menuButton' href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED --><a class='menuButton' href="{U_REGISTER}">{L_REGISTER}</a><!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a class='menuButton' href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
<a class='menuButton' href="{U_FAQ}">{L_FAQ}</a>
<!-- IF S_DISPLAY_SEARCH --><a class='menuButton' href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --><a class='menuButton' href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT --><a class='menuButton' href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF --></div>
<form action="search.php" id="cse-search-box">
<div id='searchbox'>
<input type="submit" value="" class="searchy"/>
</form>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<div>
<div class='menu_top'><div class='menu_top_l'><div class='menu_top_r'>
</div></div></div>
<div class='m_l'><div class='m_r'><div class='menu_text'>
<table width="100%" cellspacing="0" align="center">
<td align="left" class="lefttext">
<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<br /><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a><!-- ENDIF -->
<td align="right" class="righttext">
{CURRENT_TIME}<br />
<td class="forumheader2">
<p class="breadcrumbs"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
<p class="datetime">{S_TIMEZONE}</p>
</div></div></div>
