trying to install 1.0.3
There are no instructions for code edits for Subsilver2? In the install or upgrade package?
Is this correct?
I completed the install, and the first thing I notice is there is no link in the left menu block for ACP?
I did refresh the style, imageset, theme, & template, plus purge the cache, several times.
I can't see any difference in the Portal ACP panel in .Mods, am I missing something?
edit:
Ok I see you moved the ACP link to the User.
I see there is a problem in the user menu, or at least with my style "AcidTech Tiger"
See the images below
![Image](http://i296.photobucket.com/albums/mm161/yocalif/vwmainuser.jpg)
![Image](http://i296.photobucket.com/albums/mm161/yocalif/vwtestmainuser.jpg)
v1.0.2 v1.0.3
Notice all the annoying lines in v.1.03?
edit by Marc: merged the two posts; please use the edit function next time
