No update tab in install
Onetimer
Post by Onetimer »
Your Portal Version: 1.0.3
Boardlink: localhost
I'm trying to update my DB from 1.0.2 to 1.0.3 but there is no install or update tab. If I try to load domainpath/install/install_update.php directly it just gives me a blank page.
I know this can happen with a normal phpBB upgrade if your config file has stuff written in it. If you replace that with a blank file the tabs re-appearbut that didn't help here.
Re: No update tab in install
Onetimer wrote:If I try to load domainpath/install/install_update.php directly it just gives me a blank page.
yourdomain.com/install/index.php ;)
Onetimer
Post by Onetimer »
Yeah, of course, but it doesn't show the update or install tabs. If I try to load one of the other html files they give me a blank page.
