Would like to know more about block development and modification.
I'd like to replace the analog clock with a digital clock and build my own blocks to replace some of the ones included.
Any links?
Block development?
- phpBB.de User: MB34
Block development?
MrBaseball34
Hook 'em Horns
![Image](http://www.delphicommunity.com/board/images/texas2.gif)
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
Re: Block development?
Changing the clock isn't the only thing I asked about.
I also want to develop some custom blocks. I didn't find anything in the KB
about how to do that.
MrBaseball34
Hook 'em Horns
Hook 'em Horns
Any more replies?
MrBaseball34
Hook 'em Horns
Hook 'em Horns
What exactly do you want to know... If you want to develop your own Blocks, you should be able to study the existing blocks, and convert them to your needs... right? ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
In our KB you find articles on how to add a new Block, or how to change the Order of these Blocks. The new Style system is also described in there... And what you need for the code of your Blocks, you should know better than us![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
