A little confused about theme compatibility
guardianx5
Post by guardianx5 »
Researched
N/A
Hi guys,
I was just curious if your mod only supports the prosilver/subsilver themes, or it should basically work on any style.
Thanks
PeterS
phpBB.de User: PeterS
phpBB.com User: PeterS
Re: A little confused about theme compatibility
Post by PeterS »
generally mods are designed only for prosilver/subsilver.
If you need help for another style, place your request here viewforum.php?f=39
Peter
