Hello
I am missing the update to 1.0.3 instructions.
They are there, but it is the same as the install instructions?!?
Update to 1.0.3 instructions - What?
Kind regards
Stoker
Stoker
- Tester
- phpBB.de User: Würzi
- phpBB.com User: Wuerzi
Re: Update to 1.0.3 instructions - What?
Hello Stoker,
contrib/update_board3portal_102.xml
Update from.....
Update from.....
Yes I know
My question is why it also contains the ordinary install instructions?
An axample:
Open: viewonline.php
Find:
Add after:
Why is this in the Installation Instructions for 'board3 Portal - Update from phpbb3portal 1.2.2' Version 1.0.3?
I did that edit when Iinstalled the portal.
I find it a bit confusing.
EDIT: I was looking in 122, sorry
An axample:
Find:
case 'report':
$location = $user->lang['REPORTING_POST'];
$location_url = append_sid("{$phpbb_root_path}index.$phpEx");
break;
case 'portal':
$user->add_lang('mods/lang_portal');
$location = $user->lang['VIEWING_PORTAL'];
$location_url = append_sid("{$phpbb_root_path}portal.$phpEx");
break;
Kind regards
Stoker
Stoker
