Your Portal Version: 1.0.2
Boardlink: http://deviant-mafia.com/forums/index.php
Problem does not exist at this point.
Nothing
I am trying to make the portal show in place of the index of my main site. I am fairly oblivious on how to make this happen.
For example, my portal address is http://www.deviant-mafia.com/portal/index.php
I would like the portal to show when a user types in http://www.deviant-mafia.com
Thanks in advance for any help.
Making it the main page of site
- phpBB.com User: InternetMafia
Re: Making it the main page of site
I successfully use a refresh command in my index.html page
Refresh eg.
<META HTTP-EQUIV="REFRESH" CONTENT="0;URL= http://www.deviant-mafia.com/portal/index.php">
Specifies a delay in seconds before the browser automatically reloads the document. Optionally, specifies an alternative URL to load, making this command useful for redirecting browsers to other pages.
The 0 in the above example redirects visitors to the forum with no visible delay and your index.html page should not show on their screen. Alternatively you could insert a number of seconds to display your index.html page before redirecting to the forum.
eg.
<META HTTP-EQUIV="REFRESH" CONTENT="15;URL= http://www.deviant-mafia.com/portal/index.php">
Should add a 15 second delay, displaying your sites main page before redirecting to the forum portal
This is sometimes used with a brief "you are being redirected to our site please be patient" in case the page loads slow and often there is also a Link to the portal on the page in case there is a problem with the actual redirect process.
eg.
Please wait while you are redirected to our site. If the page doesn't load automatically please click the link below
Refresh eg.
eg.
eg.
Uh! This is only temporary!
Uh! Unless it works!!!
(Red Green)
(Red Green)
I put a redirect in my .htaccess, yours would be something like this (use full line)
Redirect 301 /index.html http://www.deviant-mafia.com/portal/index.php
Back up the file first, hope it helps...
Example can be found at link below, compare link below with the link of the page your taken to.
http://www.sadisticoldbastards.com
- phpBB.de User: iamdarren
- phpBB.com User: iamdarren
hi what should the whole htaccess file look like as mine shows this at the moment
my sites address is www.t-365.co.uk
Thanks
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Thanks
I added the line to the bottom of the file. make sure your adding it to the server root .htaccess, not the one in the phpbb3 folders.
its working,
thanks for your help
now looks like this...
Order Allow,Deny
Deny from All
</Files>
Order Allow,Deny
Deny from All
</Files>
Redirect 301 /index.html http://www.t-365.co.uk/portal.php
