Where to change padding between columns?
luminosity
Post by luminosity »
Your Portal Version:
For the past hour I've been searching through portal.css trying to find where to reduce the distance between each column. I would like to reduce the distance between the left, center and right columns. Where is this variable? I do have portalview installed, but the distance was the same before as well. So I'm assuming the change I want to make has to do with board3. Thanks!
Re: Where to change padding between columns?
Open styles/*yourstyle*/template/portal/portal_body.html
Find:
<td valign="top" style="width: {PORTAL_LEFT_COLUMN}px; padding-right:6px;">
Adjust the padding to your needs.
Find:
<!-- [-] left block area -->
	<td style="width:4px;" valign="top"></td>
Adjust the width to your needs.
Find:
<!-- [-] center block area -->
	<td style="width:4px;" valign="top"> </td>
Find:
<td valign="top" style="width: {PORTAL_RIGHT_COLUMN}px; padding-left:6px;">
