(SOLVED) U_PORTAL and L_PORTAL
sbashwar
phpBB.de User: sbashwar
phpBB.com User: sbashwar
Post by sbashwar »
Your Portal Version: 1.0.2
After installation portal working fine outside the root directory of the forum board except I need to change U_PORTAL & L_PORTAL path. It will save my time if someone write which file(s) to be changed/define variables.
regards
Re: U_PORTAL and L_PORTAL
U_PORTAL is defined in includes/functions.php portal_docs/install.xml#includes/functions.php
L_PORTAL is defined in lang_portal.php
