Meta Tags / Keyword / Description
Foxy
phpBB.de User: Foxy
phpBB.com User: fujcube
Post by Foxy »
Your Portal Version: 1.0.2
Boardlink: http://www.tight-lines.net
Nothing
Nothing
Hi all,
Which files should I be editing to add:
Name
Keywords
Description
Any other advice / suggestions for getting traffic through my site appreciated.
Regards
Foxy
Re: Meta Tags / Keyword / Description
That can all be found in the overall_header.html. Don't forget to purge the cache afterwards. ;)
Moved to general phpBB3 support.
