Soft Delete Mod and Board3?
rudolfpietersma
Post by rudolfpietersma »
Your Portal Version: 1.0.2
Your phpBB Type: 3.0.4
Boardlink: http://prikbord.ilovebrasil.com
I recently installed the Soft Delete Mod from http://www.lithiumstudios.org.
The problem is on the Portal these Soft Deleted messages are still visible.
Can somebody please help to solve this issue?
Rudolf.
Ice
Re: Soft Delete Mod and Board3?
Post by Ice »
The portal would have to be modified to check for the new "deleted" check mark in the database, have a look through /portal/includes/functions.php in the phpbb_fetch_posts() function and see what you can find. I'll take a look after work.
rudolfpietersma
Ice wrote:The portal would have to be modified to check for the new "deleted" check mark in the database, have a look through /portal/includes/functions.php in the phpbb_fetch_posts() function and see what you can find. I'll take a look after work.
Hi Ice,
I don't have that much knowledge. My experience is basic.
Would be great if you can check it for me!!
Cheers,
Rudolf.
rudolfpietersma
Can somebody help me with this issue?
rudolfpietersma
I'm still struggling with this issue, please help me :o
Not tested:
Open portal/includes/functions.php
search:
            p.bbcode_bitfield,
            p.bbcode_uid,
add after:
            p.post_deleted,
search:
        'WHERE' => $topic_type . '
                ' . $post_time . '
                AND t.topic_status <> ' . ITEM_MOVED . '
                AND t.topic_approved = 1
                AND t.topic_moved_id = 0
                ' . $str_where,
        'ORDER_BY' => $topic_order,
replace with:
                ' . $post_time . '
                AND p.post_deleted = 0
                ' . $str_where,
Dunno if this is enough, but it should keep the soft deleted topics away.
rudolfpietersma
Kevin wrote:
            p.post_deleted
Great stuff Kevin, it seems to work :-)
Though it needs a comma behind p.post_deleted
So:
p.post_deleted,
Thanks a lot!
Ah, forgot that. Thanks, corrected. ;)
rudolfpietersma
Hi Kevin,
I now do see in the "Recent Topics" block a soft deleted topic. Is there a same kind of way to hide it?
Rudolf.
Yes, open portal/block/recent.php
*edit*
removed wrong code - see a few posts further
rudolfpietersma
Kevin,
I'm getting a SQL error.
SQL ERROR [ mysqli ]
Unknown column 'p.post_deleted' in 'where clause' [1054]
SQL
SELECT topic_title, forum_id, topic_id FROM phpbb_topics WHERE topic_status <> 2 AND topic_approved = 1 AND topic_type = 0 AND topic_moved_id = 0 AND p.post_deleted = 0 ORDER BY topic_time DESC LIMIT 10
Yar, wrong edit, as i thought about it.
I'll provide a correct code this evening.
rudolfpietersma
Hi Kevin,
Did you have some time to think about the correct code?
Cheers,
Rudolf.
Hi Rudolf,
sorry - forgot about that. Now the code, that should work:
Open portal/block/recent.php
search:
// Recent topic (only show normal topic)
$sql = 'SELECT topic_title, forum_id, topic_id
    FROM ' . TOPICS_TABLE . '
    WHERE topic_status <> ' . ITEM_MOVED . '
        AND topic_type = ' . POST_NORMAL . '
        ' . $sql_where . '
    ORDER BY topic_time DESC';
replace with:
        AND topic_deleted = 0
        ' . $sql_where . '
You can add the line
to the "recent hot topics" and "recent announcements" too.
Cheers
rudolfpietersma
Kevin,
Tnx a lot, that worked just great!
