Something with the database
dragz
Post by dragz »
Your Portal Version: 1.0.2
Boardlink: http://www.megalk.com
I backed up my current sql database and moved it to a new host. Almost everything works fine except the portal. When I go to the portal it says
So what do I have to do next?
Re: Something with tha database
Visiting your site, everything seems to be fine.
It would be helpful if you could post the complete error message, including the message which block causes the problem.
As well as the MySQL server versions (before and after).
dragz
Post by dragz »
I'm sorry, I restored the database in the localhost
I put it online now,
124.43.78.139/public_html/
Everything works fine when I direct it to the index.php
Thanks
Re: Something with the database
First of all: determinate which block causes the problem.
Deactivate all blocks and reactivate them one by one, until the error occurs.
dragz
Post by dragz »
Announcement and News blocks are causing the error. Thanks kevin
May be its because I didn't copy all the posts?
Hm, i don't believe so. The error message says that there is a problem with the MySQL syntax.
Kevin wrote:As well as the MySQL server versions (before and after).
Which MySQL version do you actually use and which one do you had on your old webspace?
Maybe you need to adapt this setting in your config.php file:
$dbms = 'mysql';
dragz
Post by dragz »
I changed "mysqli" to "mysql"
And this does the trick?
dragz
Post by dragz »
I did that in the first place, after that everything except the portal started working and still no solution for the news n announcement blocks
