Using Portal as index.php with a Twist
GoldStarDad
Post by GoldStarDad »
Boardlink: http://http://www.goldstardads.org/members/community/
I tried the fixes here viewtopic.php?f=10&t=350
I have the phpbb3.0 and Board3 Portal working like a fine Swiss watch including Gallery and live weather, awesome script, kudos to everyone involved. ALL of it is currently sitting in the /members/community/ folder
Here is my mission. I want to use a modified portal.php (with no News or board functions just a welcome block and a log in box, maybe my weather box, what ever but not much else) I want to call it index.php and place it in /members/
Then
When a guest logs in or completes registration they would be sent to the /members/community/which automatically is loading portal.php at this time (this would be the full Monty with newest post, Gallery links & newest pictures, everything.
BUT ~ I don't want anyone to be able to see anything on the members/community/ if they bypass login unless the session timer is still in play from a previous login.
Bassicly i am trying to use the phpbb & portal3 as a Members Only system. IS THIS POSSIBLE?
I tried to follow the directions from this thread viewtopic.php?f=10&t=350 but it didn't help
ANYONE???
Maverick
Re: Using Portal as index.php with a Twist
Post by Maverick »
Edit styles/provision/template/portal/portal_body.html
Enclose all the block "includes" e.g <!-- INCLUDE portal/block/leaders.html --> that you only want members to see with the lines:
<!-- IF S_USER_LOGGED_IN -->
example:
If you want to display something for non-members only use the alternative script:
So what you would have is a single page that does everything you wanted: showing the non-members the bits you want to see and the members the full-works. The log-in box of course already has this built in - it shows the log-in box if you're not logged in and your member information if you are. There is also an option in the ACP to only show the welcome message to non-members.
http://www.vivaf1.com - motorsport portal
