Black Pearl Width for Portal
naijababy
Post by naijababy »
I've searched and searched on both the Board3 site and phpbb.com site but I can't find any references to this yet. When I switch my style to Black Pearl, the portal looks "squished" together....I love the way the portal looks in Subsilver...nice and spread out..it fills the screen but in Black Pearl....it still has blank spaces on the side. Where do I make the changes to get rid of the blank spaces and/or increase the width of the columns. Could someone please a me out? thanks
Huor
Re: Black Pearl Width for Portal
Post by Huor »
in your template folder there should be a file called _mg_config.html. There is the width of your site defined by the line
<!-- DEFINE $MG_GLOBAL_WIDTH = 'your width' -->
just replace your width with the width you want to use (auto or * should work -> dunno haven't tested it yet).
or in a previous version for black pearl its in the stylesheet.css under wrapper defined (default was something about 960px) change this to your needs.
Hope this works for ya.
Greetz
Huor
naijababy
Post by naijababy »
YOU ARE DA MAN! Works perfectly with the _mg_config.html edit. Thanks bro! :D :D
Huor
Post by Huor »
yw - its always a plessure for me to help. Sometimes someone only needs a little impulse and the rest is done automatically ;)
