Your Portal Version: 1.0.2RC3
Boardlink: http://dv-efs.com/portal.php
PHP Version: 5
Was wondering how to edit the content of the link to us block. It still says "yourdomain.com" instead of my sites name, and i dont know how to change the anchor and link text.
Any help would be great, thanks.
Modifying the Link to Us block, need help
Re: Modifying the Link to Us block, need help
That has no effect on the anchor text in the link to us block. For instance...Kevin wrote:viewtopic.php?p=7147#p7147
<a href="yousite">Anchor text</>Re: Modifying the Link to Us block, need help
Ok i figured it out. To change the anchor text of the link (the visable url to others).
open link_us.php
Replace 'Your Text Here' with the anchor text you want, make sure to keep the single quotes!
open link_us.php
'U_LINK_US' => '<a href="' . $u_link . '" ' . (($config['site_desc']) ? 'title="' . $config['site_desc'] . '"' : '' ) . '>' . (($config['sitename']) ? $config['sitename'] : $u_link ) . '</a>',
'U_LINK_US' => '<a href="' . $u_link . '" ' . (($config['site_desc']) ? 'title="' . $config['site_desc'] . '"' : '' ) . '>' . ('Your Text Here') . '</a>',
The major problem i have now is the destination of the link.
It has the a href= set to my domain.org/phpbb3
I dont have anything in phpbb3 thus using this link results in a blank/error page.
How can i get this to simply link to domain.org with nothing else?
Ive tried changing script path, ive tried editing the file further...nothing i cahnge seems to make a difference its dead set on using /phpbb3. Should i delete the phpbb3 folder from my server?
Ok i have it figured out...
If you do not want the script path included in your link to us, these are the changes to make.
Replace
Thats it...so now it will link to a href="Yourdomain.com" instead of yourdomain.com/phpbb3.
It has worked out, not i have the Anchor text i wanted and i have it linking to my homepage. I did not tinker with trying to add an additional path or directing to a different page...but im sure it wouldnt involve much of a change in the code to do.
$u_link = $config['server_protocol'] . $config['server_name'] . $config['script_path'];
$u_link = $config['server_protocol'] . $config['server_name'];
