Your Portal Version: 1.0.2
Your phpBB Type: other phpBB Distribution
Boardlink: http://fireforumz.com
PHP Version: 5
came here.... this is the source
really bad coding errors
I run a mutli-forum host and im needing some help.
The install folder works fine, but i have to keep it in the root for other forums to install it. Can i either get the MYSQL for the install so i can enter it in the install.sql.
Or could i get a modded install folder so only a admin can install it and that the portal.php doesnt check for the installation folder?
Modded Install Help!
emoruffino
Re: Modded Install Help!
You may just disable / remove the check for the install directory, which can be found in portal.php:
if ( is_dir( $phpbb_root_path . 'install_portal/' ) === TRUE )
if ( is_file( $phpbb_root_path . 'install_portal/install.'.$phpEx ) === TRUE )
include $phpbb_root_path . 'install_portal/install.'.$phpEx;
if ( version_compare( $current_version, $portal_config['portal_version'], '<=' ) === TRUE )
$template->assign_vars(array(
'S_DISPLAY_GENERAL' => true,
'GEN_TITLE' => $user->lang['PORTAL_ERROR'],
'GEN_MESSAGE' => sprintf( $user->lang['PORTAL_DELETE_DIR'], $phpbb_root_path . 'install_portal' )
'GEN_TITLE' => $user->lang['PORTAL_UPDATE'],
'GEN_MESSAGE' => sprintf( $user->lang['PORTAL_UPDATE_TEXT'], $phpbb_root_path . 'install_portal/install.'.$phpEx, $current_version )
$load_center = false;
} The installer already checks for the user context - just admins are allowed to install the portal.emoruffino wrote:Or could i get a modded install folder so only a admin can install it
emoruffino
thanks!
also is there a way that there could be like a php eval that could redirect to portal.php or the index.php from a option in the acp?
Saint_hh http://www.phpbb.com/community/viewtopic.php?p=7270865#p7270865 wrote:Will be included in the next version.gavpedz wrote:Although you can turn all boxes off you can not actually turn the portal off as you just get the blank portal page i would love to be able to turn the whole portal on/off so that when it is off visitors/users will be directed to the normal board index and when portal is on visitors/users are directed to the portal page. how could i achieve this?
If you can't wait:
http://board3deportal.svn.sourceforge.n ... vision=394
The language edits should be like this:
http://board3deportal.svn.sourceforge.n ... athrev=402
