# # # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # # #
Aktuelle Version: 2.1.0
Veröffentlicht: 26.10.2015
Mario
Post by Mario »
# L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N # L O E S C H E N #
Re: Brotkrümelnavigation des Boards - Text "Portal"
Du könntest die Links zum Portal wie folgt entfernen,
Öffne: root/ext/board3/portal/styles/prosilver/template/event/
Lösche darin folgende Dateien: overall_footer_breadcrumb_prepend.html und overall_header_breadcrumb_prepend.html
Leere deinen Browser Cache STRG+F5
Mario
B I T T E L O E S C H E N
Post by Mario »
Wenn danach das Forum nicht mehr benutzbar war, musst du was falsch gemacht haben, wenn du die Dateien löschst sind sie ja nach wievor im Cache erst wenn dieser geleert wurde sieht man die Änderung.
Die beiden oben genannten Dateien sind nur Template Events und enthalten die Links zum Portal.
Mario
Post by Mario »
