Custom Buttons Below Header
shaka!!
Post by shaka!! »
Your Portal Version: 1.0.2RC3
I've put the buttons up through the overall_header and they are working fine and appearing everywhere in the forum except for the portal page.
The buttons are much like the ones of this forum, except they appear below the header.
I've tried to find file for the overall_header via all the portal files but I can't see any. I've searched a couple of the other files but found nothing to do with the navbar.
I'm sorry but for confidential reasons I can't share the link to my forums.
This is really annoying me. The buttons appear everywhere on the forum except for the portal page. Where should I insert my code to make it appear on the portal?
Re: Custom Buttons Below Header
Disable the main menu for checking - then the buttons should appear.
If so:
Check you edits to the overall_header, that the code for the buttons is not wrapped by this code:
shaka!!
Post by shaka!! »
Hey thanks a lot! You were right about them being wrapped in that code. It's showing just fine now.
