No Borders around blocks.
Your Portal Version: 1.0.1
Fresh install of phpBB3, just added this portal to my test site.
Checked all my code.. Seems fine
On the portal home page (prosilver) no borders appear around the block on the left and right. (no images etc)
Centre blocks are fine.
Any ideas ?
Thanks
Any ideas ?
Thanks
- Valued Contributor
- phpBB.de User: HenK
- phpBB.com User: H3nK
Re: No Borders around blocks.
Maybe you didn't upload the portal.css into the theme folder.
portal.css is there..
Any other ideas ?
THANKS
Any other ideas ?
THANKS
Did you modify the stylesheet.css properly and did you purge your theme-cache?
This is my stylesheet.css:
I presume this is correct.. I've cleared my Cache and still no borders around the left or right blocks..
Thanks for taking the time to try and help.
/* phpBB 3.0 Style Sheet
Style name: proSilver
Based on style: proSilver (this is the default phpBB 3 style)
Original author: subBlue ( http://www.subBlue.com/ )
Modified by:
Copyright 2006 phpBB Group ( http://www.phpbb.com/ )
@import url("common.css");
@import url("links.css");
@import url("content.css");
@import url("buttons.css");
@import url("cp.css");
@import url("forms.css");
@import url("tweaks.css");
Which cache did you purge?
Did you go to Styles >> Themes and cleared your style's cache?
If you didn't do that, the theme is not refreshed.
Yes I cleared the theme's cache as well as the main cache..
I think I'll restore my backups and try again !!
Reinstalled and working well.
Thanks
Now to change the blocks colour !! and maybe the menu !!
Thanks
For editing the menu you might look into this short tutorial: viewtopic.php?f=24&t=917
For changing the block's color, just open portal.css and change this part of the code:
Change the background-color to your needs.
.portal-panel {
background-color: #DDE9F0;
color: #28313F;
margin-bottom: 4px;
padding: 0 10px;
color: #3f3f3f;
Thanks.. got it sorted.
Hi there just installed this portal on my system, I also have the same problem. However If I select the subsilver theme everything is fine. I have deleted the cach via ftp and useing the system ACP Purge the cache. Please help!!!
P.S.
I have the following file located on my ftp
/phpbb3/styles/prosilver/theme
portal.css and stylesheet.css
Contents of Stylesheet.css
Modified by:
P.S.
Modified by:
Problem has been sorted, it was to do with the prosilver theme.cfg it was this option causeing the problem
parse_css_file = off.
anyway just thought I would post the solution
