Any solution to remove them would be most appreciated! Thanks
Getting a blank page, can't access site
Re: Getting a blank page, can't access site
Yes they are uploaded
So you edited stylesheet.css? Did you refresh your theme and template cache?
Thank you for a quick answer yet again.
Yes, I did refresh both template cache and i added stylesheet.
Bottom of the style sheet i've added @import url("portal.css");
Looks like this:
Edit: Everything works fine, the stylesheet seems to work properly. All except the stupid list circles.
Edit2: I think i could use in my css. However, don't know if this will ruin for anything else .. Maybe if i add it to portal.css it only goes for that part?
Looks like this:
/* phpBB 3.0 Style Sheet
Based on style: proSilver (this is the default phpBB 3 style)
Original author: subBlue ( http://www.subBlue.com/ )
Modified by:
Copyright 2006 phpBB Group ( http://www.phpbb.com/ )
@import url("common.css");
@import url("links.css");
@import url("content.css");
@import url("buttons.css");
@import url("cp.css");
@import url("forms.css");
@import url("post.css");
@import url("blocks.css");
@import url("tweaks.css");
list-style:none outside none;-
I know you added the stylesheet, but the question was if you refreshed the theme cache. That is not the template cache and also not the board cache.
Do this:
Open your ACP and click on the Styles-Tab. Now click on Themes in the left sidebar and click on refresh next to the theme of your style CA_Halcyon.
Do this:
Alrighty, got it working like a charm! Thanks for all the help!
Oh riht, ought to ask you, when you post for support you get this to fill out
our Portal Version:
Your phpBB Type:
MODs installed:
Your knowledge:
Boardlink:
etc..
Is that a mod? Seems like something I would need for my forum. Thanks again Marc!
our Portal Version:
Your phpBB Type:
MODs installed:
Your knowledge:
Boardlink:
etc..
I really have no idea what MOD it is, but I guess it is has to be some MOD. I think it's a MOD from phpBB.de, but I didn't add it to the board, so I have no idea.
I think its the support ticket mod, i already found it on phpbb.com and also @ google (only in german so far)
Yes found it as well =) Thank you
Hello,
i got same problem
Your Portal Version: 1.0.5
MODs installed: Calendar mod,medal system mod
Boardlink: http://clandecima.altervista.org/forum
PHP Version: 3.0.6 subsilver2
MySQL Version: Latest
Nothing
Be sure all edited files were utf no bom
Purged caches
Hello,
I got blank page on portal index and dunno why..
can you please help me?
my overall header
i got same problem
Nothing
Purged caches
Hello,
my overall header
<head>
<!-- INCLUDE ca_config.html -->
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF S_ENABLE_FEEDS -->
<link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" />
<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_TOPICS}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
<!-- IF S_CALENDAR_RSVPS -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/sortable.js"></script>
// <![CDATA[
var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
</head>
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td id="logorow" align="center"><div id="logo1"><div id="logo2"><table id="logorow1" border="0" cellspacing="0" cellpadding="0" width="100%">
<td id="logo-left" valign="top"><img src="{T_THEME_PATH}/images/logo_left_top.gif" width="0" height="66" border="0" alt="" /></td>
<td id="logo-mid" valign="middle"><a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>
<td id="logo-right" valign="top"><img src="{T_THEME_PATH}/images/logo_right_top.gif" width="0" height="66" border="0" alt="" /></td>
</table></div></div></td>
<td class="navrow">
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> • <!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a> • <!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><a href="{U_REGISTER}">{L_REGISTER}</a> • <!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> • <!-- ENDIF -->
<a href="{U_FAQ}">{L_FAQ}</a> •
<!-- IF U_MEDALS --><a href="{U_MEDALS}">{L_MEDALS_VIEW}</a> <!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
<td id="contentrow"><div id="content1"><div id="content2"><table border="0" cellspacing="0" cellpadding="0" id="contentrow1">
<td id="content-left" valign="top"><img src="{T_THEME_PATH}/images/content_top_left.gif" width="5" height="5" border="0" alt="" /></td>
<td id="content-mid" width="100%">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- IF not S_IS_BOT --> <a href="{U_CALENDAR}"><img src="{T_THEME_PATH}/images/icon_mini_calendar.gif" width="12" height="13" alt="*" /> {L_CALENDAR}</a> <!-- ENDIF -->
<td class="gensmall">
<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<br /><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a><!-- ENDIF -->
<td class="gensmall" align="{S_CONTENT_FLOW_END}">
{CURRENT_TIME}<br />
<!-- IF S_DISPLAY_SEARCH and S_USER_LOGGED_IN --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a> | <a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
I can see everything.
Did you try if this only happens if you are logged in?
u right man,it's everything fine!
