P.s. Ich hab die datei aktuallisiert, jedoch is das was ich nun "geaendert" habe noch nicht wichtig fuer mich gewesen. Die Portallinks oben stehen für mich gaaannnzzz hinten ^^ wichtiger is das layout
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (typeof blankImg == 'undefined') var blankImg = '{T_THEME_PATH}/images/spacer.gif';
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
<!--[if IE]><link href="{T_THEME_PATH}/ie.css" rel="stylesheet" type="text/css" /><![endif]-->
</head>
<body id="phpbb" class="{S_CONTENT_DIRECTION}">
<table id="container" cellspacing="0" cellpadding="0" border="0">
<td id="bgleft"><img src="{T_THEME_PATH}/images/spacer.gif" width="53px" alt="" /></td>
<td id="middle" valign="top">
<div id="wrapper">
<div id="banner">
<div id="header">
<div id="menu">
<a class="faq" href="{U_FAQ}" title="{L_FAQ_EXPLAIN}"><span>{L_FAQ}</span></a>
<!-- IF not S_IS_BOT --><a class="members" href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}"><span>{L_MEMBERLIST}</span></a><!-- ENDIF -->
<!-- IF not S_IS_BOT --><!-- IF S_DISPLAY_SEARCH --><a class="search" href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}"><span>{L_SEARCH}</span></a><!-- ENDIF --><!-- ENDIF -->
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN --><a class="ucp" href="{U_PROFILE}" title="{L_PROFILE}"><span>{L_PROFILE}</span></a><!-- ENDIF -->
<!-- IF not S_USER_UNREAD_PRIVMSG --><a class="nonewpms" href="{U_PRIVATEMSGS}"><span>{PRIVATE_MESSAGE_INFO}</span></a><!-- ENDIF -->
<!-- IF S_USER_UNREAD_PRIVMSG --><a class="newpms" href="{U_PRIVATEMSGS}" title="{PRIVATE_MESSAGE_INFO}"><span>{PRIVATE_MESSAGE_INFO}</span></a><!-- ENDIF -->
<!-- IF U_MCP --><a class="mcp" href="{U_MCP}"><span>{L_MCP}</span></a><!-- ENDIF -->
<br clear="all" />
<div id="crumbs">
<!-- IF not S_USER_LOGGED_IN and not S_IN_UCP -->
<form action="{U_LOGIN_LOGOUT}" method="post">
<table class="toplogin" cellspacing="0">
<td><span class="gensmall">{L_USERNAME}:</span></td>
<td><input class="post" type="text" name="username" size="10" /></td>
<td nowrap="nowrap"><input type="checkbox" checked="true" class="radio" name="autologin" /><span style="vertical-align: middle;" class="gensmall">{L_LOG_ME_IN}</span></td>
<td><span class="gensmall">{L_PASSWORD}:</span></td>
<td><input class="post" type="password" name="password" size="10" /></td>
<td><input type="submit" class="btnmain" name="login" value="{L_LOGIN}" /></td>
{S_FORM_TOKEN}
</form>
<ul class="breadcrumbs">
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> ‹ <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<ul id="navlist">
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li>
<!-- IF U_RESTORE_PERMISSIONS --><li><a href="{U_RESTORE_PERMISSIONS}"><span>{L_RESTORE_PERMISSIONS}</a></li><!-- ENDIF -->
<div id="ct"><div id="ct2"><div id="ctl"><div id="ctr">
<div id="cb"><div id="cbl"><div id="cbr">
<div id="wrapheader">
<div id="wrapcentre">
Cache habe ich ueber die Allgemeine registercarte im ACP geleert und bei den styles die einzelnen dinger auch .. kA was das prob grad is* styles/subsilver2/template/breadcrumbs.html,
* styles/subsilver2/template/overall_header.html
SELECT username FROM phpbb_users WHERE user_id not in(select vote_user_id from phpbb_poll_votes where topic_id = 92) and user_type = 0
