I am glad you found the problem
/Ghostman
overall_header.html error
Re: overall_header.html error
i just do exactly what you have said, but, unfortunately, those full string is not present in my template, so i only search part of the string, and my search, lead me to the wrong place ,Marc wrote:The install.xml says to search for the code mentioned above and tells you to add the code after it.
The code I mentioned is right after the code you were supposed to look for. If you add the code right in front of it, it's still the same place.
